does anyone NOT have tranny problems 6MT - Page 9 - MustangForums.com
5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Old 06-04-2012, 12:14 PM   #81
AKElroy
AKElroy's Avatar
Quote:
Originally Posted by knightryder View Post
I'll have to disagree with the above statement about the 11's not being ready. When push comes to shove you'll find that the vast majority of 11 owners reporting no problems far outnumber the ones that did. Now I realize this is of little consolation to the owners that have experienced issues, however these issues are not unique to Ford. If you peruse other forums dedicated to the likes of Challengers and Camaros you will find the same issues plaguing a certain percentage of their owners as well.
I don't see Camaros rolling a ring with a mild tune, or trannies frequently whining like a Hewland straight cut box. When they replace parts with new OEM parts that have a different low-friction coating, then the original parts were issued wrong. As for the Challenger, Dodge encrypts the ECM to prevent tunes. If Ford wants to blame tunes for blown #8's, they need to explain why this has never been the case with the 4.6, some of which are banging 600+ w/o rolling a ring. It would also be helpful if they would not market the car as a blank slate just itching for the aftermarket, and then deny claims when folks scratch that itch. If the car can't handle a mild tune, then they should lock the ECM.
AKElroy is offline   Reply With Quote
Old 06-05-2012, 07:40 AM   #82
fordplay
First off the camaro’s have more than double the TSB’s the mustangs do, GM also invented the “customer satisfaction program” to fix future items without it counting against their government tracked TSB and recall count… look it up air bag fixed convertible top fixes, (don’t even get started on those lemons) so you got a tuner that screwed you and leaned it out too much or turned off or down your knock sensors (before you fly off into a rage on how you have a great tuner, look it up, call bama, call evolution, ask them what caused these issues and why they have pretty much vanished, it’s not a giant ford cover up) you should be happy ford let you strip off your aftermarket items and they fixed it under warranty!!! These engines run close to the ragged edge stock, you lean it out too much, desensitize a knock sensor and toss in some 91 gas on a 93 tune and push it… (not saying you put 91 in that’s what happed on another case) and bang.. as for the trans.. sometimes bad parts happen, nothing you can do about it, before you blame ford you do realize that ford had input into the transmission gearing but that it’s built by another company right? It’s kind of like blaming ford if your Pirelli tire developed a bulge in it? The transmission is developed by GETRAG.. I understand this is a fly by night mom and pop company… but it’s their transmission. You think ford went to them and said “we need this gearing, this size case, this weight, oh and built in china!!” I doubt that came up. As for your new parts with “low friction coating” I assume you have something on this other then the word of a service advisor?
fordplay is offline   Reply With Quote
Old 03-23-2016, 01:16 PM   #83
Fyrhog
Fyrhog's Avatar
Default 2012 Gt
17000 on my 2012 GT and she moves through the gears very nicely. Im going to change to MTL and disconnect that Skip-Shift ,,,just doing these 2 things because of what I learned on here,,OH also Royal Purple HPS 5W-30.
Fyrhog is offline   Reply With Quote
Old 03-24-2016, 03:46 PM   #84
knightryder
33,000 on my 2011 GT. No issues at all and I like to row the gears pretty aggressively.
knightryder is offline   Reply With Quote
Old 04-05-2016, 02:14 PM   #85
Miket2573
Default Miket2573
I have shifting problem till I added blowfish racing trans mount to hook up shifter to trans so it stayed in line with trans when getting on it hard all gears lined up perfect no miss shifting
Miket2573 is offline   Reply With Quote
Old 04-22-2016, 07:55 PM   #86
Machfive916
2011 GT with .373 gears, 34 K miles and no transmission or shifter issues.
Machfive916 is offline   Reply With Quote
Old 04-23-2016, 10:34 AM   #87
HRDWRK
I have blowfish support and whiteline insert. They have helped specially with straight line aggressive take offs but if you are in any kind of turn or side to side move, the 3rd gear still locks up on occasion.
HRDWRK is offline   Reply With Quote
Old 05-31-2016, 10:39 AM   #88
Fyrhog
Fyrhog's Avatar
Default 2012 GT
My MT82 is great. I did put in MTL fluid and disconnected the skip shift. I do double down when shifting,,just a old school thing I do. The linkage feels fine but Im thinking of going with MGW just because of the reviews are so good.
Blew my rear end :( 67LimeCoupe 5.0L (1979-1995) Mustang 31 09-30-2015 05:46 PM
transmission inspection cover prophotog Classic Mustangs (Tech) 2 09-15-2015 09:38 AM
Noob needs help! 86 mustang svo motor swapped to 71 5_speed carb 302 v8 jaiidutch Motor Swap Section 2 09-14-2015 11:29 AM
1077hp / 909 ft lbs torque 4V 4.6 motor angeljoelv SVT Forums 0 09-10-2015 10:12 PM
AODE Woes Pyrate Dave 5.0L (1979-1995) Mustang 8 09-10-2015 08:30 PM
2012, 2013, boss, cai, gt, gt500, installing, intake, issues, jlt, manifold, mustang, shelby, transmission, trouble
