Struts for my ride, suggestions?
To be honest it's going to kinda be difficult to do what you want. To increase handling, you have to make the suspension pieces stiffer (which decreases ride comfort, however much depends on the specific part).
You could go with Tokico D-Specs which are adjustable (from full soft to stiff) and feature a lifetime warranty, which is what I would suggest if you decide that you are ok with going with a stiffer ride for increased handling.
If your going to change your front struts, you might as well replace the springs while your at it. You are going to have to take the stock springs and struts apart anyways. If going too low is your concern, then go with a 1" drop from FRPP or similar you'll be very happy that you did. As far as stuts, you can go with Koni STRT's (non-adjust) or Koni sports(adjust) or Tokico D-spec (adjustable). I run Tokico's and are very satisfied with their performance.
We also have Pro-Action shocks which are not adjustable, but feature a good ride quality and increase in handling, that do not require the upper spring isolators from the GT500 upper strut mounts.
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
