Custom Catchcan Setup I made for my dads mustang
Since you are handy with fabrications:
I saw a catch can once (can't remember where....) that plugged directly into the hole the PCV valve was supposed to go. The unit was about 2" tall and the PCV valve plugged into the top of the catch can.
The beauty of this design is that you never have to empty it. The oil that is stopped by the catch can just drips back into the valve cover. I thought it was genius in it's simplicity.
BTW, I love the looks of your unit! That is some nice welding.
Here a couple of the focus
Thanks on a street car setup i wouldn't want to do a drain back setup, moisture forms inside of a catch can making a milky solution and you don't want that back in the engine
heres a couple more weld pics from different projects
BTW, awesome focus! What kind of numbers do you run with that?
Not to be argumentative, but that milky junk (moisture) is commonly in your engine when it is cold. When the car is driven and getting up to normal running temp, that stuff burns (evaporates) off and you are left with clean oil again.
I took the Focus out on pump gas 454whp to the track a couple weeks ago, I ended up blowing out the internals in the IAC valve causing it to no build boost on the 2-step. With me bogging a 1.998 60ft it still went 11.8 @ 120 something. Ive taken it to the 1/8 mile and trapped 101mph which i was happy about. it trapped 100mph on the 11.8 1/4 pass.
