5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Dyno run today. 325HP seems awful low
Old 07-22-2012, 06:57 PM
UberDuper
UberDuper's Avatar
Default Dyno run today. 325HP seems awful low
I haven't received the graph yet and I didn't see the torque number at the dyno. 2 pulls came up at 325HP on a dyno dynamics which seems really low for a stock '13 GT.
I *think* the pulls were done in 4th. With 3.73 gears is that a reasonable peak? I'm reading that it should have been done in 5th.
I'll post the graph when I get it. I'm just kinda bummed and wanted to get some feedback.
UberDuper is offline
Old 07-22-2012, 07:09 PM
MoshpitMad
MoshpitMad's Avatar
That's odd. What were the temps like and humidity?
MoshpitMad is offline
Old 07-22-2012, 07:10 PM
UberDuper
UberDuper's Avatar
Low 90s out and probably ~70% humidity
Old 07-22-2012, 07:15 PM
q8stang
q8stang's Avatar
i own a dyno dynamics, if the dyno was not on "comparison mode" reading "flywheel hp", then your number seems correct. keep in mind dyno jet (industry standard number) reads 20% higher than a dyno dynamics
q8stang is offline
Old 07-22-2012, 07:22 PM
UberDuper
UberDuper's Avatar
Hopefully the run report will have some details on it. Was a $40 "dyno day" run so I didn't ask for details. Just said it was lower then expected. I was expecting around 350 - 360 somewhere.
Old 07-22-2012, 07:23 PM
Senderofan
Senderofan's Avatar
Yep...I think you're right...fifth gear is 1:1 on the manual gear box. Also...I think atmospheric conditions were not in your favor....which would also lower your peak numbers.
I had my truck dyno'd this past Wednesday. The guy has one on a trailer and does it outdoors....same temp and humidity as you describe. He kept my hood down and got my numbers on the third pull....the runs were back to back to back so I was thoroughly heat soaked. Anyway, I know I was down probably 20-30 hp and torque maybe 50-100 ft/lbs ???. I would say....schedule a pull when temps and humidity are down....and make sure you're in the proper gear to make the pull. I would have thought you'd have pulled more than you did as well.
Don't get too bent out of shape...lots of variables that can really impact the bottom line when making pulls.
Wayne
Senderofan is offline
Old 07-22-2012, 08:26 PM
MrSandman
MrSandman's Avatar
Needs to be 5th gear.
MrSandman is offline
Old 07-23-2012, 12:30 AM
UberDuper
UberDuper's Avatar
Wouldn't 4th gear show higher numbers then a 5th gear pull? I'm a little confused on this.
Old 07-23-2012, 08:55 AM
siggyfreud
siggyfreud's Avatar
The numbers wouldn't change THAT much, but would probably be lower in 4th, due to needing less power to accomplish the same amount of work.
They may do them in 4th, if 5th is going to make you hit the speed limiter on the car.
siggyfreud is offline
Old 07-23-2012, 10:01 AM
UberDuper
UberDuper's Avatar
That's a good point. I don't know what the limit is on these cars but 7k in 5th is 150mph.
I'm hearing from others on a local forum that this is a well known low reading dyno and my numbers are in line with similar mustangs.
Quick Reply: Dyno run today. 325HP seems awful low
