5.0L V8 Technical DiscussionsAny questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Welcome to Mustang Forums!
Welcome to Mustang Forums.
I have a 2 1/2 ton hydraulic floor jack the I want to use to rotate my tires-front to back.
I want to jack up one side so I can rotate each side front to back. If I put it mid-point of the car's side, where specifically do I jack it from so as not to bend or break anything???
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
I know the lift points are the pinch welds but I dont like jacking cars up there. I lift mine from the K-member and rear diff. Only problem is you need jack stands for this. If you had frame connectors they would be ideal for a one sided lift.
yeah. I'd get jack stands... well.. that's what I did. then jack it where Boss said, jack stands are cheap, and you should use them any time you jack up your car anyway for safety.
I get where you're coming from -- I like to jack the car up from the side when I'm changing tires too. But the concern about the pinch-weld is valid -- that's why I purchased a jacking insert just for this purpose.
There are others that make inserts as well (UPR comes to mind) but I liked the design of this one and the fact that it doesn't need to be welded to the side rail.
So does this just slip on when you need to use it? And do you put it in the center and jack up the entire side of the car?
__________________
Old car: Xcharger Xtreme #020 PB: 12.61 @ 107.
I like that insert never used one. Looks like it just slips over the pinch weld. I have had my car up multiple times on the pinch welds no problem. Depending on the job however I have used other spots. What are you jacking it up for. That would help with placement.
__________________
Loose is fast and on the edge of out of control...
2012 Mustang GT
Pypes catback super system, bbk x pipe, steeda cai, boss 302 intake, brenspeed 93 octane race tune. Steeda lower control arm upper control arm front and rear sway bars sport springs fays watts linkage system steeda shocks tri ax short shifter.
This forum is owned and operated by Internet Brands, Inc., a Delaware
corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford
Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor
Company
