Intermittent CEL for P0300, 0303, and 0305
I just got this car last Thursday and started getting an intermittent CEL, it's at the service dept now and I'm hoping it's something simple. Sometimes I got a flashing CEL, other times it stayed on, but has turned itself off several times. When it happens it seems like I'm usually under acceleration but not always. If coilpacks are the culprit, does anyone know if they're covered under warranty? I should know what the deal is in a few hours.
If the cylinders at fault change each time you go to check the cel codes then you may be dealing with a random misfire.
http://www.obd-codes.com/p0300
zanemoseley
09-06-2015 12:58 PM
