5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Starting problems
Old 08-04-2013, 06:34 PM
88stangturbo
88stangturbo's Avatar
Default Starting problems
So got a 1988 302 with a 70mm turbo
Problem is when I go to start it I got nothing.
No fuel pump noise
No starter noise
Will not turn over
Got new starter
New starter relay
Still nothing
Any ideas???
Thanks
88stangturbo is offline
Old 08-04-2013, 07:23 PM
Shane780
Shane780's Avatar
Default differnt 5.0
Probably should look in the fox body threads.
Did you install the turbo kit yourself ?
Did you buy it running and then it doesnt run no more ?
Did you buy it not running ?
If you bought it not running it could be many things...
No fuel pump noise means no power, i usually start at the source of the power and then follow the switches grounds, IE battery>ground wire>fuse box>etc. That being said, get power to the fuel pump and go from there. Being an older car and a turbo kit, it could be as simple as a bad ground. BUT tracing for broken wires is time consuming.
Shane780 is offline
Old 08-04-2013, 08:34 PM
88stangturbo
Yea got it not running put the turbo in myself
Thanks alot. Will check all those things out
Old 08-05-2013, 12:01 AM
Shane780
Shane780's Avatar
Default project
I have never installed a custom turbo setup, so I cant be any much further help. It not running befor you got it, could be so many things. makes me think of one project stang where, everything was replaced fuel pump-injectors and distributor-ignition switch, timing was dead on. Turns our car was rear ended once and the fuel line above the gas tank was pinched shut. Try looking for junk yard turbo set ups, you might find a specific forum that would yield more accurate and quicker answers.
Shane780 is offline
Old 08-05-2013, 12:29 PM
88stangturbo
I will have a look at everything front to back.
Thanks for your help
djbigskrilla
09-20-2022 01:04 AM
jjwinel78
08-17-2015 03:34 PM
cvarner131
08-17-2015 07:38 AM
KEM Motorworks
08-14-2015 10:13 PM
Pain.
08-07-2015 10:48 PM
Quick Reply: Starting problems
