Automatic Shift RPM's? - MustangForums.com
5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Old 08-05-2013, 05:01 PM   #1
DarkCandy08GT
Default Automatic Shift RPM's?
I see most tuners set the shift RPM's on an auto at 7K some as high as 7500. Yet looking at dyno's it seems the engine starts losing power around 6500. Has anyone tried different shift points and had better results with the rpm set at 6800 or found better at 7K plus?
DarkCandy08GT is offline   Reply With Quote
Old 08-05-2013, 10:06 PM   #2
radioguy1
radioguy1's Avatar
Quote:
The FRPP tune shifts at about 6800 RPM. Probably the only way to see what is best is at a dragstrip and looking at the 1/4 ET. Then, your differential gearing, and what gear you can go through the trap, is probably a big factor in deciding at what RPM to shift.
radioguy1 is offline   Reply With Quote
Finally got the turbo 3.7 to the track JimC Street/Strip 15 10-07-2015 08:02 PM
Automatic tuner recommendations nboost 5.0L GT S550 Tech 7 09-16-2015 06:35 AM
Pinion angle, poly bushings, 1 piece DS mtgldr S197 Handling Section 1 09-10-2015 10:43 PM
Shifting Mustangmalo General Tech 2 09-06-2015 06:22 PM
