new coyote need x pipe off road opinions
I've searched and i'v read all kinds of exhaust posts, but all about sound and axle backs. My 5.0 is not in a mustang so after the x pipe or h pipe I'm custom with side exit exhaust. I'm looking more for fit and performance. I'm wondering should I go with cat delete pipes like below then I have more options for x-pipes or should I just go with a complete off road x pipe. Is the magnaflow true x really worth twice as much as other brands?
Here is what i just got installed, great fit great sound great power, amd they're t-304 stainless steel!
http://www.jpcracing.com/stainless-w...replaces-cats/
http://www.stainlessworks.net/produc...467&model_=661
or
http://www.lethalperformance.com/201...ad-x-pipe.html
or the JPC pipes mentioned above.
Many good options. Good luck.
or
I went with a set of jegs cat deletes for now and a used stock h pipe. I wasn't sure if the stock stuff would clear my crossmember. I had to notch cross member I wasn't happy how it looked so i bent up a new tube one. now i can run any one made for a 2011 -2013. thanks for the suggestions.
I added the BBK cat deletes...took about 4 hours by myself. It's a much cheaper route to go as opposed to the Magnaflow system. The only issue I had was that it leaked a little...which i solved with a new clamp.
not all mustang but almost all ford
Still need to get a stater, alt, power steering pump,all the ac components, like condenser, compressor etc. Need pressure plate bolts and bolts for starter and bellhousing.
http://www.modularfords.com/attachme...chmentid=93279
If you don't mind, keep us up to date with the build. It sounds bad ***. I just sold a 78 short bed 4x2 to a friend at work. I had a 351w, Holley 4 barrel, single plain intake, long tubes, with a C6 put in it. Since then, he has added trick flow heads, cams, a stall, 390 gears and soon to be a 300 shot added to it. He also is in the process of doing the crown vic front end conversion. It will be a nasty little truck when he gets it done. Makes me wish I had kept it and done the same build. Anyway a coyote swap is even better. I tried to talk him into going that route but he wants to keep it old school.
Like I said. Keep us up to date. Would love to see some post build videos.
Matt's 95 Stang
10-05-2015 07:16 AM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
09-24-2015 09:18 PM
