5.0L CAI INSTALLATION WRITEUP - MustangForums.com
5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Old 09-28-2013, 12:23 PM   #1
mmarker
Default 5.0L CAI INSTALLATION WRITEUP
For most people this is pretty easy. I'm creating this writeup for those nontechnical types and people that didn't get instructions with their CAI.
mmarker is offline   Reply With Quote
Old 09-28-2013, 12:26 PM   #2
mmarker
Step One.
Remove the engine cover by simply lifting up and removing.
Old 09-28-2013, 12:33 PM   #3
mmarker
STEP TWO
LOOSEN THE HOSE CLAMPS ON THE FACTORY INTAKE TUBE
Throttlebody
FILTER BOX
Old 09-28-2013, 12:37 PM   #4
mmarker
STEP THREE
USING A PAIR OF PLIERS DEPRESS THE HOSE LOCK TABS AND DISCONNECT THE RESONATOR TUBE FROM THE INTAKE TUBE
GENTLY DEPRESS THE HOSE LOCK TABS AND DISCONNECT THE CRANK CASE BREATHER LINE AND BRAKE ASPIRATOR LINE(AT ONLY)
Old 09-28-2013, 12:39 PM   #5
mmarker
STEP FOUR
AFTER ALL HOSES ARE REMOVED AND HOSE CLAMPS LOOSENED REMOVE THE INTAKE TUBE
Old 09-28-2013, 12:42 PM   #6
mmarker
STEP FIVE
DISCONNECT THE MAF SENSOR BY GENTLY PULLING OUT THE RED TAB AND REMOVING THE HARNESS
AND REMOVE THE AIRBOX COVER
Old 09-28-2013, 12:45 PM   #7
mmarker
STEP SIX
LOOSEN THE AIRBOX RETENTION BOLT USING A 10MM SOCKET AND REMOVE THE RESONATOR TUBE STAND FROM THE BOX
Old 09-28-2013, 12:47 PM   #8
mmarker
STEP SEVEN
REMOVE THE AIRBOX BY PULLING UP
Old 09-28-2013, 12:50 PM   #9
mmarker
STEP EIGHT
INSTALL THE GROMMET AND POST FOR THE CRANK CASE BREATHER LINE AND THE BLANK (MT ONLY) OR GROMMET AND POST (AT ONLY) FOR THE BRAKE ASPIRATOR LINE
Old 09-28-2013, 12:53 PM   #10
mmarker
STEP NINE
REMOVE THE MAF BY USING THE TWO SCREWS USING A T-15 TORX BIT FROM THE STOCK AIBOX AND REINSTALL IT INTO THE AFTERMARKET AIR TUBE.
Comcast "customer service" JimC Off Topic 22 09-11-2015 09:00 PM
Pinion angle, poly bushings, 1 piece DS mtgldr S197 Handling Section 1 09-10-2015 10:43 PM
First Mustang 99' 3 differnt body kits installed TimeLord101 New Member Area 3 09-04-2015 10:27 AM
Help! Metra 70-5521 AMP Harness Install cbird1177711 2005-2014 Mustangs 2 09-03-2015 09:43 PM
