Brembo spare tire delete help
O.K. I got my 2014 GT 3 weeks ago, and I just noticed there is no lug nut wrench! I knew about the spare-tire delete. I assume the wrench was deleted too, because I have the Brembo package. This means no spare wheel since it will not work with the oversized Brembo calipers, so no lug-nut wrench required, since I will not be changing any wheels. . .?
For those of you who may not know, Ford puts an air compressor (with a patch compound inside) in place of a spare. Am I correct? I could not find one! I ended up buying a wrench so I could put the locking nut on each wheel. What do some of you recommend? Thanks!
I went to Harbor Freight Tools and picked up a cheap scissor jack and folding lug wrench. It all fits in the recess for the spare tire. I also bought a plug kit. At least this way if I get a flat somewhere I can at least remove the wheel and avoid having the car towed. I've had good luck with tire plugs on my motorcycles and won't leave home without them?
It sounded like you did not find the Ford compressor in the tire well? If not your dealer should supply you with that.
jwog666
12-27-2021 08:09 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
