5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
First Oil Change Time, Which Oil?
Old 02-22-2014, 11:48 AM
  #31
GCCBrian
GCCBrian's Avatar
I own an 06 GT, but I run Mobil 1 Full Synthetic. Walmart sells gallon jugs for $24.99. As long as you're changing your oil every 3-5k you're good. I change mine every 3,000 miles, or sometimes every 2,700 miles just because I'm pretty OCD with my ****. I'm going to be switching to amsoil pretty soon.
GCCBrian is offline
Old 02-22-2014, 12:35 PM
  #32
Nuke
Nuke's Avatar
Originally Posted by 70monte
... I have never seen any hard facts that show an engine will last longer using a synthetic vs not using one....
IMO, using full dino oil or using full synthetic, providing you're changing the oil at the proper frequency for each will have little if any affect on engine longevity and if that's the reason people switch to full synthetic then they need to educate themselves. Yes, full syn tends to provide slightly better lubricating properties on a cold engine but 90% of the population will be rid of the vehicle before any consequences occur, IF they occur.
The benefit of using full synthetic is extending your oil changes, period. I typically drive in excess of 30k miles per year and prefer to be under the car 3 times/year or less vs. 10 (dino) or 6 (blend). I have 3 other vehicles, a boat, 4 dogs and 6 1/2 acres to take care of. Full syn is a time saver and I can go beyond my normal 10k mile changes without worrying if I have to. Multiple vehicles sold at 200k+ miles with no engine malady's has been my experience.
Nuke is offline
Old 02-23-2014, 05:15 AM
  #33
70monte
70monte's Avatar
Unless you do oil analysis, just because you run a full synthetic does not guarantee you can extend oil changes. I found that out years ago with Mobil 1 in my vehicles.
I also don't mind getting under my car or under the hood more than a few times a year. Sometimes you can catch problems before they get too serious.
Wayne
70monte is offline
Old 11-21-2014, 09:03 AM
  #34
devereiii
devereiii's Avatar
What do you guys think about Castrol GTX? I've used that in my, bought new in 2000, '99 Chevy Cavalier Z24, religiously, every 2K miles (yes, I was **** about it being my first new car), and made it to 247K miles with not one oil leak or engine noise; up until I totaled it just this past July, water skiing during a HEAVY sudden downpour.
Obviously, I'm a Ford guy now , and I love my new Black '14 GT that I just took delivery of last week. (Started with a Satin Silver '06 V6 which started me on my modding path and was my undoing, lol). So I'm at 400 miles right now, and I will do the 1000 mile change. I do believe that no matter how tight tolerances are and clean manufacturing processes are, there will be matter in your factory oil fill.
I just want to get a good feel for what I should use for my first change. If any of you know of analysis done on Castrol GTX, I'd be interested to hear. Obviously, my personal experience with it has been good. Otherwise from what I'm reading I might think about switching to Penzoil as my oil for the 'Stang.
devereiii is offline
Old 11-21-2014, 09:13 AM
  #35
bluebeastsrt
bluebeastsrt's Avatar
Wayne
I work at a refinery and we have done studies on our equipment and synthetic oil does extend the life of rotating equipment. Sometimes as much as 3-5 times the normal lifespan of conventional oil. And refinery equipment runs 24-7, sometimes for months on end. Extending oil change intervals has more to do with the contaminates in the system then on the oil breaking down. Both conventional & synthetic oil will last a 10K oil change interval no problem. If your car is old and operates in a dirty environment like dirt driveways change the oil more often. If the car is new and only sees highway miles change the oil as often as the owners manual suggests. In the case of my wifes 2011 Camaro SS they recommend every 10,000 miles.
bluebeastsrt is offline
djbigskrilla
09-20-2022 01:04 AM
algregory
09-06-2015 05:52 PM
landomar2014
08-17-2015 04:27 PM
OBleedingMe
08-08-2015 12:02 PM
Quick Reply: First Oil Change Time, Which Oil?
