5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
2011 GT Automatic Slight Miss
Old 03-15-2014, 09:49 AM
LWT96
LWT96's Avatar
Default 2011 GT Automatic Slight Miss
I have a slight miss at idle and mild acceleration. It threw 3 codes P0300 Random Misfire, P0302 Cylinder 2 misfire, and P0304 Cylinder 4 misfire a couple months ago. I was able to duplicate this same issue and i took it to Ford a couple weeks ago. Told me i needed new plugs and coils at cylinders 2 and 4. I had already replaced the plugs 300 miles before so i ordered a set of coils and replaced the entire set. Engine light went off but it still has the slight misfire especially at lower RPMs. Any ideas?
LWT96 is offline
Old 03-15-2014, 09:57 AM
LWT96
LWT96's Avatar
Additional information. This started when the car was stock except for the GT500 ehaust. Before i tried to fix it i added a JLT cold air intake and a BAMA tuner thinking the tune might help this problem. Took it back to stock before i took it into Ford. Reloaded the tune and intake after replacing the coils.
LWT96 is offline
Old 03-16-2014, 08:49 AM
gixxxerdan
gixxxerdan's Avatar
what kind of code tester do you have? Is it an SCT scanner?
gixxxerdan is offline
Old 03-17-2014, 03:35 PM
scottmach
scottmach's Avatar
Why were you replacing the coils?
scottmach is offline
Old 03-18-2014, 09:49 AM
P51C
P51C's Avatar
I'd be looking at ckp (crankshaft position sensor). Critical to engine timing and there is a tab out about this item needing a replacement o ring for earlier cars iirc.
P51C is offline
Old 03-26-2014, 01:26 PM
LWT96
LWT96's Avatar
Sorry so late in replying. Yes I have a sct bama tuner but o'reilly pulled the codes for me. Ford dealership confirmed the codes.
LWT96 is offline
Old 03-26-2014, 02:09 PM
LWT96
LWT96's Avatar
Coil and plug replacement recommended by ford dealer for cylinder 2 & 4. I had already replaced the plugs and I could replace all the coils for what ford wanted for two.
LWT96 is offline
Old 03-26-2014, 02:11 PM
LWT96
LWT96's Avatar
Having them add the o ring and perform the entire TSB 13-6-15 today. They claim misfire when driving in cylinders 1, 2, 4, and 5 now with 2 being the main culprit. I guess we will see if this works or not.
LWT96 is offline
Old 03-28-2014, 08:55 PM
LWT96
LWT96's Avatar
Ford performed TSB 13-6-15. Did not help. Back to the drawing board.
LWT96 is offline
Old 03-31-2014, 09:47 AM
Andy13186
Andy13186's Avatar
had the same misfire type issue, it was my crank position sensor
Andy13186 is offline
Quick Reply: 2011 GT Automatic Slight Miss
