5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Dragging a 2013 GT
Old 04-01-2014, 07:01 PM
scottmach
scottmach's Avatar
BMR can back up their claims.
scottmach is offline
Old 04-03-2014, 11:44 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Originally Posted by MCBigDog
How serviceable is the stock drivetrain (clutch, driveshaft, axles, gears) for a fairly steady diet of drag racing? At some point it will all be replaced with heavy duty components but I don't really want to wait. I'm already getting the rear suspension in order, welded tubes, UCA, LCA's, Panhard & Brace, LCA lowering brackets, shocks. It's a manual so I want to run a 10" wide slick. Will the stock stuff hold up or will I be scattering parts everywhere?
Nobody mentioned the differential, but that's a common failure. I saw two of them break on the same day at NMRA Bradenton last month.
UPRSharad is offline
Old 04-04-2014, 04:29 AM
huntiez
huntiez's Avatar
I got a 2012 stick when I play I normal do a rolling start havent launched it yet after my last car a 2010 maro shattered a axle at a 2k drop I know the stang is a solid rear but still kinda scared whats a safe rpm to drop it at
huntiez is offline
Old 04-04-2014, 08:33 AM
P51C
P51C's Avatar
the diff's durability depends on alot of factors. You don't see stock auto cars breaking them as the hit is softer. Similarly, slick-shod manual cars fare better than drag radial cars in this respect.
If you're on street tires, a drop is out because they won't hold and you'll go up in smoke. 2000-2500 on a stick and bleed the clutch in and whatever the flare rpm is on the auto, on street tires.
I run slicks and dump my manual at 4500. It didn't 60 faster dumping it higher, although it held just fine up there.
P51C is offline
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
Florida Regional Chapter
09-30-2015 08:04 PM
guitarman376
09-30-2015 05:54 PM
stealth_GT
The Racers Bench
09-22-2015 02:19 PM
Quick Reply: Dragging a 2013 GT
