5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Confusion aboout fuel recommendation
Old 04-28-2014, 05:27 PM
Chromeshadow
Chromeshadow's Avatar
I think it was R&T that did a dyno run on the 3.7 and got 7 more hp on 93 than on 87. I've run several tanks of both on mine and did not feel any difference or see any difference in mileage. I usually run the mid grade gas on both the 3.7 Mustang and the 5.0 F150.
Chromeshadow is offline
Old 04-29-2014, 09:33 PM
Callinectes
Callinectes's Avatar
I fill up once a week. I figure the 93 costs me $3.20 a tank over 87. I understand that the 87 actually burns hotter. More heat=more wear and tear. For me, it's worth $12.80 a month.
Callinectes is offline
Old 04-30-2014, 09:36 AM
The Sheriff
The Sheriff's Avatar
That's very interesting & good to know. Where did you get this information?
The Sheriff is offline
Old 04-30-2014, 09:51 AM
Mishri
Mish-ogynist
Mishri's Avatar
There were some reports of people who once they put 87 in, it would never go advance the timing again for higher octane gas (This was with 2011, 2012, I don't know if they fixed it). Luckily I've only ever put 91 in (93 isn't available here, we have 85.5, 88, and 91)
Mishri is offline
Old 05-02-2014, 09:25 AM
BrazenStang
BrazenStang's Avatar
If you went to the doctor and he/she "recommended" that you stop eating fast food and eat healthy, would you listen? Ford engineers recommend premium fuel for a reason because it is better for a high performance engine.
Personally, I choose to follow my doctor's recommendations and I also follow the fuel recommendations for my car. Its your choice, but in the end they are the experts. Is it worth the few dollars per fill-up to skimp on gasoline?
BrazenStang is offline
Old 05-02-2014, 01:46 PM
Troponin
Troponin's Avatar
Most dealerships will put 87 in cars if they can get away with it, so don't bet on it never having 87 put in it. I think the GT500 is the only car they actually fill up with premium.
Troponin is offline
Old 05-02-2014, 01:59 PM
HRDWRK
HRDWRK's Avatar
Ford is recommending 87 in their manual for 5.0 engine! That was the cause of confusion.
HRDWRK is offline
Old 05-02-2014, 02:20 PM
AJ06GT
AJ06GT's Avatar
That's because the cars are tuned for 87. 87 will have absolutely no adverse effect on your engine. Traditionally changing your octane does absolutely nothing for performance or gas mileage, but with as complex as engines are getting and automatically adjusting, I've heard it rumored that the Coyote engines can actually get a gain from 93, even without a tune, but I've yet to see any official source confirm this. A dyno run can easily fluctuate a few HP between each run, so that's not really the best indication either since you're going to be talking a very small difference without a real tune. I'd have to see some kind of hard evidence to prove that 93 actually does give you a power boost to believe it though. It is a difference of less than $3 a tank though if you do want to run it, but I highly doubt you'd notice a difference if you just used 87.
AJ06GT is offline
Old 05-02-2014, 10:22 PM
Troponin
Troponin's Avatar
I am pretty sure it's in the Ford owner's manual, but even on the Ford website, all off their hp claims are with premium. So yes, Ford has confirmed the car will adjust the timing to run regular in it safely, but performs best with premium.
http://www.ford.com/cars/mustang/specifications/engine/
Troponin is offline
Old 05-03-2014, 02:58 AM
AJ06GT
AJ06GT's Avatar
Oh, well then yeah, so with premium it's going to tune up. I'd always heard people talk about it but no one had ever posted a link like that before. I'd probably pay the extra $3 or so a tank, but the difference is probably barely noticeable. You'd still want a specific 93 tune to really get everything out of it otherwise paying for just 87 will still be fine which is why the manual states that.
AJ06GT is offline
Quick Reply: Confusion aboout fuel recommendation
