5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Hellion Twin Turbo Install
Old 05-07-2014, 08:35 AM
postmastrr
postmastrr's Avatar
Default Hellion Twin Turbo Install
I've decided to go with the Hellion Twin Turbo setup for my coyote, and I'm also opting to install it myself. I've done headers on my old 2003 Mach 1 so I already know the headaches that come with that, but as far as anything else goes...anyone on here install this system themselves? I've found a couple good threads where people don't really go step by step, but they take photos and explain special things they did. What kind of headaches am I to look forward to? Bending and rerouting A/C and brake lines, moving the fuse box and PCM, oil lines, just the stuff that could end up biting me in the a$$ if I'm not careful doing. This post isn't for those of you who want to talk crap about a turbo setup vs. a SC setup. I'm just asking for some friendly advice, from one mechanic to another.
postmastrr is offline
Old 05-07-2014, 02:08 PM
jdback19
jdback19's Avatar
You are looking at a solid 2 day install. Take your time and dont rush anything. I installed a single turbo kit on my 2006 GT and it was a hellish experience. I dont know how they run the oil return on the twin kit for the coyote but on the 4.6 drilling and tapping the oil pan while it was on the car sucked huge *****.
jdback19 is offline
Old 05-07-2014, 02:14 PM
postmastrr
postmastrr's Avatar
I'm planning on removing the oil pan and installing bulkhead fittings. Not huge on the idea of tapping and threading fittings.
Old 05-07-2014, 02:15 PM
postmastrr
postmastrr's Avatar
I also plan on having this car on jack stands for at least a week. I want it done right.
Old 05-08-2014, 08:59 AM
jdback19
jdback19's Avatar
Thats the spirit! Yeah I would advise not drilling and tapping. I did and the bitch started leaking like 4 days later. Make sure your car has almost no gas in it. When you start changing out the fuel pumps under the back seat you dont want that stuff spilling in your car. My car smelled of gas for about 2 months.
jdback19 is offline
Old 05-08-2014, 09:02 AM
postmastrr
postmastrr's Avatar
According to hellion and other folks I talk to I shouldn't need to replace the fuel pump with the 49 lb/hr injectors. I know it wouldn't be a bad idea, but like I said, I've heard it isn't necessary.
Old 05-08-2014, 10:49 AM
jdback19
jdback19's Avatar
I would do it. Thats the last thing you want to have "an overworked fuel pump". I'm also not familiar with the coyote motors fuel system so I could be dead wrong. Keep us posted on the install. I will eventually be going back to a turbo setup and it would be awesome to see how the hellion kit works out for you.
jdback19 is offline
mtgldr
02-03-2024 09:00 PM
Granatelli Sales
03-21-2016 06:16 PM
Luke9222
10-22-2015 11:55 PM
mmarsh3014
Wheels & Tires
10-20-2015 09:08 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: Hellion Twin Turbo Install
