5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
help going to next level SC vs turbo
Old 06-16-2014, 09:08 PM
vega17
vega17's Avatar
Default help going to next level SC vs turbo
I want to get more power for my 13 GT pony, actually I have few bolts on, but im at 5000ft above sea and the gains are not the best, i have 2 options continue n/a or go SC or turbo
My actual modifications are:
Engine
-JLT carbon fiber intake
-Kooks long tube headers
-Custom 3" exhaust with X pipe
-3.73 gears
-custom dyno tune
Suspension
-Eibach pro kit springs
-SR performance lower control arms
-BMR adjustable panhard bar
-BMR Non-Adjustable Rear Upper Control Arm & mount (installed next week)
-Subframe connectors (installed next week)
Brakes
-stoptech drilled and slotted rotors
-Hawk HPS brake pads
-Ferodo dot 4 brake fluid
-Upgraded brake lines
Option 1 n/a
-boss 302 intake manifold
-Stage 1 compcams camshafts (maybe stage 2)
-ford racing 90mm throttle body
option 2 going forcer induction
-Procharger stage II intercooled sistem
-Kennebell 2.8lt water cooled system
-hellion single turbo kit
opinions?
i have a question, what are the "limits" of the coyote engine with stock internals (pistons, crankshaft, valves etc) only changing inyectors I mean can i go with any of my options without changing anything in ny engine? whats parts should i change to keep mi car "safe" (crankshaft, differential etc)
thanks
vega17 is offline
Old 06-20-2014, 09:27 AM
AKRA
AKRA's Avatar
Option 3: Roush or VMP Supercharger with 82 mm pulley. This will give you a safe 10 psi that will yield you about 650 FW-HP or 570 RW-HP. Only puts boost when at hard acceleration so when driving normal you don't see extra wear on motor/SC and maintains good mpg.
AKRA is offline
Old 06-23-2014, 01:26 AM
vega17
vega17's Avatar
thanks, im going take a look on the vmp
vega17 is offline
Old 06-24-2014, 10:42 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Engine
-3.73 gears
-custom dyno tune
Suspension
Brakes
Option 1 n/a
opinions?
thanks
I strongly recommend the UPR-spec ProCharger kit. I ran 10.89 @ 128 at FULL WEIGHT on 19/20 rims with this kit on my 2011 5.0. Call us at 561.588.6630 for more details, if you'd like.
UPRSharad is offline
jwog666
12-27-2021 08:09 PM
TCStangerv6
10-11-2015 05:57 PM
mdj89
10-08-2015 09:16 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
guitarman376
09-30-2015 05:54 PM
Quick Reply: help going to next level SC vs turbo
