A question revisited; when should I get my first oil change? - Page 2 - MustangForums.com
5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Old 06-25-2014, 09:08 PM   #11
PeteInFlorida
PeteInFlorida's Avatar
GLOCKer, your 2014 Mustang GT comes with synthetic blend from the factory. I changed mine before the 1000 mile mark. I have always done this with a new engine. I changed my oil at the 5000 mile mark, then will change it again at around 10,000 miles. I live in Florida, where the temperatures reach 95 daily. Consider that, plus the heat from the asphalt, idling with the A/C on in traffic, and taking the engine up to redline every so often. Changing oil more frequently than every 10,000 miles is more than just "piece of mind". It's just common sense. I paid 29,000 hard-earned dollars for my car, so neglecting it is not an option.
PeteInFlorida is offline   Reply With Quote
Old 06-25-2014, 09:09 PM   #12
PeteInFlorida
I forgot to mention that at 5000 miles I switched to full synthetic.
Old 06-25-2014, 09:45 PM   #13
jz78817
jz78817's Avatar
Quote:
Originally Posted by steel pony View Post
The book may say 10,000 but the warranty service is 7500.
Nonsense. "The book" (aka the owner's manual) says what Ford recommends you do. They're not going to tell you an oil change interval of 10,000 miles is OK then void your warranty if you don't change it at 7,500. That would be patently ****ing stupid and would practically invite all of their customers to sue them.
Quote:
Just took the 13 in for the first oil change and it said right on the paperwork:
"To keep your warranty service in good standing, oil must be changed before 7500 miles"
it was at 7604 when it went in
this is a load of crap. it's your dealer trying to scare you into giving them more money. the owner's manual says to change the oil when the oil life monitor says to, and gives a rough guideline as to when it might tell you the oil needs to be changed. Anyone who says it needs to be done on a set interval (and uses scary language like "warranty in good standing") is only looking to vacuum money out of your pocket.
jz78817 is offline   Reply With Quote
Old 06-25-2014, 10:23 PM   #14
Nuke
Nuke's Avatar
I'll go 10k miles on full synthetic, maybe more depending on what those 10k were like but only 6k-7k, tops, on the blend. For the first change, some people have the notion that keeping the factory oil in for that 10k helps the break-in period but I don't subscribe to that. If it bothers you, I still wouldn't change it before 5k miles but after that, I'd feel comfortable with a 10k frequency providing I was going to the track.
Decades ago, the theory was to change the factory oil early due to casting grit from the manufacturing process. That isn't an issue since the process has evolved significantly.
Nuke is offline   Reply With Quote
Old 07-09-2014, 04:56 PM   #15
Rusnak_322
My 2013 that I bought with 5,800 miles on it had the change oil light on. What would cause it to come on so early?
The car was very clean and owned by a 60+ year old, the stock tires looked almost new.
Rusnak_322 is offline   Reply With Quote
Old 07-09-2014, 05:30 PM   #16
jz78817
jz78817's Avatar
the oil life monitor tracks a number of things. a lot of short trips where the engine doesn't get good and warmed up will shorten the oil life due to contamination.
Old 07-28-2014, 01:48 AM   #17
J7erry
I change mine every 5k regardless. Had a 2013 V-6 and oil monitor usually said 50+% life remaining whenever I took it in. Car always "felt" better after a change, but it's your choice. As far as an oil separator, get one! I never heard of that before I got on this forum, but I got one anyway. Boy, does it work! Can't believe how much oil it catches.
J7erry is offline   Reply With Quote
2005 GT fuel problem Cin K New Member Area 4 08-31-2015 08:31 AM
ford warranty landomar2014 2005-2014 Mustangs 13 08-17-2015 05:27 PM
Need Help Diagnosing Have Codes (Confused) djbigskrilla 2005-2014 Mustangs 13 08-11-2015 01:59 PM
ford warranty landomar2014 New Member Area 4 08-11-2015 07:39 AM
2015 Mustang Oil Change Help OBleedingMe The New S550 2015-2016 Mustang 0 08-08-2015 01:02 PM
