brembo mustang brake line upgrade? - MustangForums.com
5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Sponsored by:
Sponsored by:
Old 08-01-2014, 05:47 PM   #1
RWHEELS
Default brembo mustang brake line upgrade?
I have a 2011 mustang gt with the brembo brakes, stock front pads, hawks in the rear, stock fluid and lines. I have done multiple autocrosses, multiple days driving aggressively in the mountains, and so far the brakes have been perfect, however I'm going to my first track day at a roadcourse in a few weeks and I'm considering upgrading the brake lines to either stainless or boss lines. My question is: how good are the stock brembo lines? And are the boss lines even worth upgrading to?
thanks
Rob
RWHEELS is offline   Reply With Quote
Old 08-01-2014, 05:57 PM   #2
gmoran1469
If the stock lines on the GT500 are anything to go by then they are rubber and need to be upgraded if you really plan on putting some heat into them. I went with goodridge stainless lines and I've been running them for nearly 5+ years with no problem.
gmoran1469 is offline   Reply With Quote
Old 09-02-2014, 09:29 PM   #3
darksky1984
darksky1984's Avatar
Stainless cables are great but not necessary. What is necessary is that you have your brake fluid switched with DOT 4 or your fluid will boil over and leave you without brakes on a race track. I have done many track days with the stock lines without any issues. The brembo pads are tough but once they wear down I recommend getting something better when you replace it.
darksky1984 is offline   Reply With Quote
Old 10-01-2014, 05:58 PM   #4
RWHEELS
well I went with boss lines and ATE amber fluid, spent 5-6 15 min hard sessions on the roadcourse, and brakes were great, definitely a great bang for your buck mod!
1995 Mustang GT- 8.8 Overhaul Urambo Tauro 5.0L (1979-1995) Mustang 22 09-07-2015 12:47 PM
2013 GT500 GB/BS, 3,700K miles, All options except glass roof, 8yr/36k mile ESP inyadreems Mustangs For Sale 2 08-21-2015 09:10 AM
Need Help Diagnosing Have Codes (Confused) djbigskrilla 2005-2014 Mustangs 13 08-11-2015 12:59 PM
Just swapped motor exhaust want fit daytooday Motor Swap Section 2 08-11-2015 09:22 AM
New Guy on the Forum with braking issue FD725 New Member Area 3 08-11-2015 03:43 AM
