engine break in question - Page 2 - MustangForums.com
5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Sponsored by:
Sponsored by:
Old 08-25-2014, 03:54 PM   #11
Slowbra302
Slowbra302's Avatar
Quote:
Originally Posted by Gary Ugarek View Post
Breaking in a Mustang:
Step 1; get in car
Step 2: Start car
Step 3 leave driveway
Step 4: Find 2 miles of straight road
Step 5. Stop dead on road
Step 6 mash pedal to floor
Step 6 take engine to full WOT aka 148 mph
Step 8 Wave hi to Doc Borwn and mArty McFly
Step 9 bet you never recognized I missed step 7
Step 10, take selfie of huge smile on your face.
Best advice ever!!! Couldn't of said I better myself!!
Slowbra302 is offline   Reply With Quote
Old 08-26-2014, 03:25 PM   #12
Nuke
Nuke's Avatar
Although today's engines don't necessarily require break-in like they did 20-40 years ago, just drive with a little bit of caution but don't baby it. I'd vary the cruising speed and duration with a few... "spirited"... jaunts to 90 or 100 mph if you have the stomach (my 4.6L saw 130 for the first of many times in the first 600 miles). Do you think they roll off the assembly line and are tested by someone's grandmother?
Nuke is offline   Reply With Quote
Old 08-26-2014, 07:11 PM   #13
jz78817
jz78817's Avatar
Quote:
every car comes off of end-of-line and goes over to the rolls (chassis dyno.) After a diagnostic check it goes up on the rollers and the tech runs it up to an indicated 60 mph and coasts down, then gets another diagnostic check. I can assure you they don't do that gently.
jz78817 is offline   Reply With Quote
Old 08-27-2014, 01:46 PM   #14
jRaskell
Quote:
Do they run wide open throttle right up to redline and bang off the rev limiter for a few seconds? Not really sure what your point is there.
jRaskell is offline   Reply With Quote
Old 08-27-2014, 02:39 PM   #15
Gary Ugarek
Gary Ugarek's Avatar
If you ain't hitting the rev limiter than you're not doing it right.
Gary Ugarek is offline   Reply With Quote
Old 08-27-2014, 04:55 PM   #16
scottmach
scottmach's Avatar
Absolutely.
scottmach is offline   Reply With Quote
02' GT Convertible, Need help choosing intake manifold. Calizic 4.6L (1996-2004 Modular) Mustang 5 08-28-2015 02:46 PM
New member from Cali Tyoung68 New Member Area 7 08-25-2015 05:31 AM
Cam swap on 68 289 ding56 Classic Mustangs (Tech) 3 08-14-2015 03:40 AM
engine swap 69 classic69FB Motor Swap Section 1 08-13-2015 12:58 AM
A/C Compressor & Engine Cooling Fan Failure - Chicken or the Egg HIS S-197 4.0L V6 Technical Discussions 1 08-10-2015 06:47 PM
