5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
change oil pump with S/C??
Old 09-13-2014, 07:59 PM
BenV8
BenV8's Avatar
Default change oil pump with S/C??
Hi guys, I need info about supercharger setup. Someone here has heard about if you install a supercharger setup you need to change the oil pump because the stock oil pump can explode?
many thanks
BenV8 is offline
Old 09-15-2014, 07:25 PM
BenV8
BenV8's Avatar
someone who have a supercharger setup has changed his oil pump?
BenV8 is offline
Old 09-16-2014, 03:34 PM
scottmach
scottmach's Avatar
It's the RPM's that are detrimental to oil pump gears, not power. With a power adder I would keep shift points around 7000 on the stock shortblock.
scottmach is offline
Old 09-16-2014, 05:51 PM
BenV8
BenV8's Avatar
ok thanks for your answer!
BenV8 is offline
Old 09-16-2014, 06:34 PM
siggyfreud
siggyfreud's Avatar
When I rebuilt my 4.6 motor Brenspeed highly recommended I use a stock oil pump and not go to a high volume or high pressure pump.
siggyfreud is offline
Old 09-26-2014, 02:22 PM
13MustangGTvert
13MustangGTvert's Avatar
many thanks
If you are talking about the new coyote motor, as someone else said has nothing to do with power adders but has all to do with how hard you drive it. Stock oil pump has a crappy plastic gear in it and if it breaks the tolerances in these motors are so tight as shown with how thin a oil they run, you can't shut them down fast enough without damage usually. Best insurance is a new pump with billet gears if your gonna start modding and driving a little spirited.
13MustangGTvert is offline
Old 09-28-2014, 10:46 AM
BenV8
BenV8's Avatar
many thanks for the info!!
BenV8 is offline
eastexsteve
3.7L V6 Technical Discussions
12-04-2015 05:41 AM
97SN95GT
09-13-2015 09:45 PM
5.0 kevo
09-03-2015 06:24 PM
whatsup62
09-03-2015 01:38 PM
Quick Reply: change oil pump with S/C??
