Coyote 8.8 ring and pinion swap vs new edge 8.8 ring and pinion swap
Does anyone know if the install of a ring and pinion on a coyote would be the same procedure as a new edge? The reason I'm asking is I heard that the coyote had slightly different components in the rear end compared to a new edge? I changed my my old 2003's before and it was a pretty straightforward installation. Just don't want to get in over my head before I start. Any advice is appreciated!
It shouldn't be. I bought the Ford install kit and it came with the Koyo bearing you pictured 2nd. Maybe you just grabbed the wrong bearing out the kit?
There is also at least one more possible inner pinion bearing for the 8.8 housing. B1 kit bearing on the left and Timken M802048 on the right.
Matt's 95 Stang
10-05-2015 07:16 AM
KingRando
10-02-2015 08:06 AM
