5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
2013 Tail lights Out yet Brake and Blinkers lights work - HELP!
Old 08-23-2016, 09:47 PM
Jaybird1975
Jaybird1975's Avatar
Default 2013 Tail lights Out yet Brake and Blinkers lights work - HELP!
Hi, I have a 2013 GT/CS. Until a week ago I had no idea my tail lights were not working until someone pulled up next to me at a stop light and was like "hey, do you know your tail lights are out?". What's weird is that the tail lights still blink when I hit the lock button on the key fob, and the blinkers and brake lights work. I noticed a water leak in my trunk the other day after heavy rain and hoping some wires didn't short out. Of course now I'm at 56k miles and out of the B2B warranty so a trip to the dealership won't be covered. Has anyone had this issue? Hoping it might be something as simple as a fuse, but I'm clueless..
Jaybird1975 is offline
Old 08-24-2016, 12:15 PM
jz78817
jz78817's Avatar
both taillights are out? I would start with fuses. Hopefully it's not a problem with the BCM...
jz78817 is offline
Old 08-24-2016, 10:02 PM
Jaybird1975
Yes, both tail lights are out... but the blinkers and brake lights work.. so weird
Old 08-28-2016, 12:39 PM
P51C
P51C's Avatar
Well, job one since you know you had a water leak is to disconnect the plugs, clean them with contact cleaner, regrease with dielectric grease (any parts store carries these things). Then see how you fare. The brake lights and hazards are on a separate circuit from the running lights so, it isn't that weird, really.
P51C is offline
Old 11-02-2016, 07:13 PM
Jaybird1975
Forgot to post the fix...
It turns out it was simply the 15amp fuse which is in position 22 in the front passenger seat fuse box. After this has happened twice, I realized that it was blowing due to some cheap *** ebay "white LEDs" that I was putting in the license plate lights. For some reason these cheap ones (2.99) kept blowing that fuse. I guess it pays to buy the good Raxium ones from AmericanMuscle.com
Old 11-24-2020, 11:50 PM
Mike Stuchlik
Mike Stuchlik's Avatar
yes i have 14 gt and mine leaked from the intake cabin filtera leaf clogged up hole and water poured on my fuseboxit took 3 trys to eal it 13 gromett holes and i used my kan filter old one after i cleaned and dig out the rubber do dad in hole get rid of it.also w auto silocone seal all around class and doors but its under windshield wiper areas
Mike Stuchlik is offline
Old 03-22-2024, 12:33 AM
Benny20
Benny20's Avatar
I have a 2017 mustang gt with only the left side taillight working! Anyone know how to fix this? It does light up when I hit the unlock button!
Benny20 is offline
StreetGhost
10-02-2016 11:28 PM
Azrael.nc
04-05-2016 09:31 AM
KobraKommander13
03-07-2016 12:47 PM
Lee1911
03-03-2016 08:05 PM
84CopperGT
02-22-2016 10:40 PM
Quick Reply: 2013 Tail lights Out yet Brake and Blinkers lights work - HELP!
