2014 GT suspension options question
I am repairing a damaged 2014 GT and I need to replace the front struts. The sellers are asking if the car has a "performance suspension package" and I don't have an answer.
Can I tell this from the VIN or the door post sticker?
THANKS - Car is at a shop so I can't look till tomorrow.
In any event some sellers are saying a different front strut for a Brembo brake car as opposed to a non-Brembo brake.
Some say all the same. Anybody know?
Cover all your driving needs and install a set of STRANGE front adjustable struts # S6011LM.
Further to this, in addition to being late on my part, it's important to make note of which shocks/struts do not differentiate between stock and performance OEM suspension.
When a strut/shock mfg only shows one number for both types of suspension, what you end up with is a compromise in performance that is typically at the detriment of the sport suspension. They won't give the strut/shock the same valving and performance as the sport suspension so you end up with either slightly better performing stock shock/strut and a slightly worse performing sport suspension or, a stock shock/strut which ruins the sport suspension.
