Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-17-2003, 12:54 PM   #1
acmeyer
Default 98 to 94 engine swap
All,
I can get a 98 232 with 26k for 700$ but the bone yard said the 94-98 are not a direct swap. I should be able to use my existing fuel rail and accessories on this vehicle correct. I know I should go with the 99+ but looking for a quick swap for now. Any help would be appreciated.
Thanks Tony
__________________
"It is Better To Burn Out Than
acmeyer is offline   Reply With Quote
Old 03-17-2003, 11:43 PM   #2
noslow50
I ♥ Acer
what the hell is a 232???
noslow50 is offline   Reply With Quote
Old 03-18-2003, 07:24 AM   #3
knupxfon
the block on the 98 should match directly to the 94 motor mounts. You may have to switch out some of the sensors. I think the 98 have larger fuel injectors so you would probably have to use the injectors off of the old engine. The engine setups are the same. same size and the sensors are in the same place. I think the sensor plugs are different, which is why you would have to use the old sensors. I just swapped a 99+ engine into my 94. I had to have a new fuel rail made to add a return line to the 99 rail. I also had to switch the camshaft sensor. I also had to cut and splice the injecotor plug wires from the 99 harness to the 94, because the plugs on the injectors are different. I also had to cut and splice a few of the other sensor plugs to work with the 99 sensors I could use. I also had to lengthen some of the wires on the 94 harness cause the sensors are in different places. Also when you switch to a 99+ you need to use the 99 MAF sensor, because the 99 uses 21lb injectors and the 94 uses 14 lb injectors. I was able to use the 94 computer. I recommend getting the 99+ engine. It's got 50 more HP and the swap is about the same as it would be to swap the 98.
knupxfon is offline   Reply With Quote
Old 03-20-2009, 11:57 AM   #4
5mustang0
Vehicle: 1995,ford,mustang
Default swap
Would a 95 5speed 5.0 engine and trani fit a 95 v6 5speed
5mustang0 is offline   Reply With Quote
Old 03-20-2009, 12:28 PM   #5
moontang
moontang's Avatar
Vehicle: 2004 VEE****INGSEXY
Send a message via AIM to moontang
Moor or less but its a waste of money
moontang is offline   Reply With Quote
Old 03-20-2009, 03:29 PM   #6
ESG-642T
Send a message via AIM to ESG-642T Send a message via Yahoo to ESG-642T
99+ is a quick swap, do it.
__________________
Block .20 Bore 3.830, ARP Head Studs, Ford Girdle, Scat 4340 Forged 6.125" H-Beam with Ross Forged Dished Pistons 8:7:1 compression, KPP Cam Reground 224* .587" Intake / 222* .567" Exhaust 114 LCA, 110 IC, Self Ported Heads with Self Ported Upper intake ported lower intake with a matching ported throttle, Mac long tube headers, Flow master 40 series mufflers, 3.73 motive gears, Eaton posi trac, Sct livewire, Bilstien shocks and struts, Eibach pro kit springs. FS: POLISHED VORTECH V2 3.8L KIT
ESG-642T is offline   Reply With Quote
Old 03-20-2009, 05:48 PM   #7
Fink
1999 Ford Mustang
Fink's Avatar
Vehicle: 1999 Ford Mustang
[quote=noslow50;1343]what the hell is a 232???[/Q]
232cubic inches = 3.8L=V6
281cubic inches = 4.6L=V8
302cubic inches = 5.0L=V8
__________________
Mods:
MAC LT's & O/R H, ROUSH Side Exhaust, GT Rear Sway, SCT X3, Auburn LSD w/ 3.27's
Waiting:
Cobra Brake Kit Front and Rear, KYB GR-2 Shocks/Struts (waiting on C/C plates)
Quote:
Originally Posted by brian1570 View Post
now RS is gonna come in here and start sh!tting on his keyboard again.
Fink is offline   Reply With Quote
Old 03-21-2009, 07:37 AM   #8
Flake6899
Send a message via AIM to Flake6899
Dude don't spend $700 on a single port engine....or a split port. you can find split ports(99-04) usually around $400-450 with pretty low mileage. PM this guy.
http://www.3.8mustang.com/forum/showthread.php?t=242873
__________________
1999 3.8L 5 Speed
CAI, dual exhaust, SCT xcal-2, 100 wet shot, FRPP 4.10's, auburn posi, Hurst short shifter, Aluminum driveshaft, P&P intakes and heads, SPEC Stage 1 Clutch
2001 SVT Cobra 5 speed
Appearance: Roush Stage 3 front bumper, Roush stage 3 rear spoiler, 18" black saleen wheels, smoked clear corner headlights, chrome bumper inserts.
Performance: SLP o/r x-pipe, Borla Catback, BBK CAI, Comp Cams
Flake6899 is offline   Reply With Quote
Old 03-21-2009, 10:25 AM   #9
5mustang0
Y would it be a waist of money n wat mods would I have 2 do as oppose 2 99+
Old 03-21-2009, 11:06 AM   #10
5mustang0
Wat mods would I have 2 do 2 the 99+ 2 fit the 5.0 enine n trani
2002, 21lb, 38, 9498, enine, injectors, mustang, swap, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
