New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-23-2007, 02:30 AM   #21
94Blk5.0
94Blk5.0's Avatar
Default RE: 3.8L poor gas mileage 13 MPG
That does not expalin the gas on the spark plugs.
__________________
1994 GT - Black on Tan - 302 - T-5 - Bullitt Wheels - 9.2 @ 77.4
1996 F150 - 351 - E4OD - 4X4 - Towing/Handling/Super Cooling Package
American Made
94Blk5.0 is offline   Reply With Quote
Old 08-23-2007, 01:37 PM   #22
blknismo180
i here an EGR valve may cause bed gas mealage as well but you need to take it to get cleaned......
blknismo180 is offline   Reply With Quote
Old 08-23-2007, 01:55 PM   #23
leitzpower
Here is more information. The EGR has low flow ( no back pressure, 4 psi at the DPFE sensor) so i doubt the cats are clogged. I have replaced the EGR system but the code keeps coming back.They said i need to clean the egr port in the throttle body (haven't found that port yet). I have been told that EGR has nothing to do with the gas mileage issue. When I bougth the car they had the wrong MAF sensor. The throttle body and egr intake ports were full of black carbon. That is why I changed my O2 sensors and MAF. I was told to look at replacing the coolant temperature sensor. I doubt the coil pack is bad. If it was bad or if I had bad injector flow it should be throughing codes (misfire). I have already run multiple cans of Seafoam through the tank.
I appreciate all the great input. Please keep it coming.
bl
leitzpower is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
