Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-12-2007, 07:22 PM   #11
roughneck9725
Default RE: Turbo!!!
It was 230.00. I will keep everyone informed. Cobra, if you dont like it, dont look. I did the research and checked the compressor map. I did the map, it will work. It may not be ideal, but then again, I am going with what I got. Thats the beauty of hotrodding and DIY builds. Thanks for the support guys. Here is the map, sorry if its hard to read, but you can see the plotted points across the bottom. Its from 3000 to 5500 at 8 psi max.
__________________
1989 Mustang LX Notchback
Carbed 302 (EFI Coming soon)
Aluminum J heads
Victor JR intake
Speed Demon Carb
Long tube headers
3.73's
Pro 5.0 Shifter
12.23 best time so far.
roughneck9725 is offline   Reply With Quote
Old 09-12-2007, 10:15 PM   #12
cobra232
Quote:
ORIGINAL: roughneck9725
never said i didn't like it. it's a gret turbo but just too small. back when i had my 86 that turbo was king in that car for the street but tuning was not like it was today either. just trying to keep you from making a mistake. a T70 or a Dodge diesel takeoff Holset HX35Y is a much better choice. the air demands of the 3.8 are rather high and can take alot of air especially if the heads and intakes are ported. i would hate to see you run a turbo that runs out of steam by 4,000 rpm's which running only 1 of those will do. that would make for an awsome twin setup
__________________
current mods
98 3.8L 11psi P1SC Procharger,97 junkyard engine ,3.73`s,7.5 Detroit Truetrac,TA rear girdle,B&M shift kit,2500 stall
mods to complete
8.5:1 ross .030" pistons,Eagle H-Beam 351W rods,Comp cam 224/236 .569"/.578" 112* lobe sep,Rhodes variable duration roller lifters,Pro-M Univer MAF,siemens deka 60lb injectors, upgrade to D1@20psi,Delk Main Girdle and Main studs, Head studs,Comp 1.7 roller rockers, home ported heads CFM 216/196,PI 3500 stall
cobra232 is offline   Reply With Quote
Old 09-13-2007, 02:31 PM   #13
roughneck9725
Sorry, rough day yesterday. I just dont want someone flaming me for trying. I go with what I can afford. I will upgrade down the road when I can. I think it will be good for 300 HP the way it is now, with some tuning and a boost cooler. Then I can upgrade. I want to do a v8 swapdown the road anyway. Sorry hardcore v6 guys, but the aftermarket hasnt got on board with the 3.8 the way it has with the v8. If it does, maybe I will change my mind. But I still think a moderate HP v6 will be a blast to build, so here I go.
__________________
Aluminum J heads
Victor JR intake
Speed Demon Carb
Long tube headers
3.73's
Pro 5.0 Shifter
Old 09-13-2007, 06:25 PM   #14
LilRoush
2000 Ford Mustang
LilRoush's Avatar
Vehicle: 2000 Roush
Send a message via AIM to LilRoush
You won't see more than 220 hp or so with that as a single unit, and you'll see max boost prior to getting mid way into your RPM range.
__________________
~Matt
Race car: 2000 Roush #5004
Shark hauler: 2001 Explorer Sport 4.0L
Show car: 1970 Mach 1 351
LilRoush is offline   Reply With Quote
60ar, compressor, explorer, hx35y, map, t04b
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
