Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-10-2007, 10:01 PM   #1
roughneck9725
Default Turbo!!!
Ok, my turbo arrived today. It is a t3/t04b. My new welder is arriving wednesday and I will start the custom build. I will start at 4 psi until I can upgrade my fuel system. It will be a long road, but Iam on my way. I will post pics soon. Wish me luck. Oh, its a 2002 v6. My final goal with this turbo is 350 HP to the wheels. I plan to keep it looking as stock as possible. I LOVE the sleeper look.
__________________
1989 Mustang LX Notchback
Carbed 302 (EFI Coming soon)
Aluminum J heads
Victor JR intake
Speed Demon Carb
Long tube headers
3.73's
Pro 5.0 Shifter
12.23 best time so far.
roughneck9725 is offline   Reply With Quote
Old 09-10-2007, 10:04 PM   #2
LilRoush
2000 Ford Mustang
LilRoush's Avatar
Vehicle: 2000 Roush
Send a message via AIM to LilRoush
Default RE: Turbo!!!
When do you get the other one?
__________________
~Matt
Race car: 2000 Roush #5004
Shark hauler: 2001 Explorer Sport 4.0L
Show car: 1970 Mach 1 351
LilRoush is offline   Reply With Quote
Old 09-10-2007, 10:23 PM   #3
eaglecatcher
lol, really. Twin turbos sounds so much cooler anyways.
Quote:
ORIGINAL: LilRoush
__________________
Black 98 Mustang V6 5MT, AutoX Project
Smoked Headlights and Corners
K&N Air Filter
Tokico Blue HP Shocks
Stangsuspension.com Springs
eaglecatcher is offline   Reply With Quote
Old 09-11-2007, 07:59 AM   #4
roughneck9725
Gonna go with a single set up for now. I do intend to go twin down the road, but funds are tight. I am in the military, not exactly the highest paying organization around. Plus I have three kids. If I put my oldest sons mouth under the hood I think I could beat a viper.
__________________
Aluminum J heads
Victor JR intake
Speed Demon Carb
Long tube headers
3.73's
Pro 5.0 Shifter
Old 09-11-2007, 06:48 PM   #5
LilRoush
2000 Ford Mustang
LilRoush's Avatar
Vehicle: 2000 Roush
T3/T4 hybrid is too small of a turbo to run it as a single on the 3.8L - just a heads up.
__________________
~Matt
Old 09-11-2007, 07:54 PM   #6
roughneck9725
I know it is small, but I dont plan to spin the engine very high until I get either another turbo or set up a twin. I did the calculations and looked at the compressor map and It will be relativly efficient up to 5500, then it drops off the map. We will see what happens.
__________________
Aluminum J heads
Victor JR intake
Speed Demon Carb
Long tube headers
3.73's
Pro 5.0 Shifter
Old 09-11-2007, 09:43 PM   #7
roughneck9725
Ok,now I have some new info. I have done a ****LOAD of research and even used some turbo calcs and I am just where I need to be. It is a .60AR compressor and 1.15 AR turbine housing. Again, I am running across the bottom half of the compressor map, but I am within specs for the turbo and can expect over 300 HP with 10 lbs of boost and a relatively efficient intercooler, I just need to keep it under 6000 rpm (which I fully intend to do). I intend to go with meth injection as opposed to an intercooler. Anyway, getting ahead of myself. First of is install and 4lbs of boost for "hopefully" around 230 HP. I will post results, but dont hold your breath as it will take a couple of months to aquire the rest of the system and fabricate my exhaust. Been awhile since ive welded exhaust pipe so I will do some test runs first.
__________________
Aluminum J heads
Victor JR intake
Speed Demon Carb
Long tube headers
3.73's
Pro 5.0 Shifter
Old 09-11-2007, 10:39 PM   #8
cobra232
Quote:
ORIGINAL: roughneck9725
incorrect. the T3/T04B is too small for the single. it will spool full boost at about 2900rpm's. i had a T04B on my 86 buick T-type and it was too small and you are talking about running a hybrid which was designed for 4cyl cars???
you need 2 of them or just 1 holset HX35Y or 1 T70
__________________
current mods
98 3.8L 11psi P1SC Procharger,97 junkyard engine ,3.73`s,7.5 Detroit Truetrac,TA rear girdle,B&M shift kit,2500 stall
mods to complete
8.5:1 ross .030" pistons,Eagle H-Beam 351W rods,Comp cam 224/236 .569"/.578" 112* lobe sep,Rhodes variable duration roller lifters,Pro-M Univer MAF,siemens deka 60lb injectors, upgrade to D1@20psi,Delk Main Girdle and Main studs, Head studs,Comp 1.7 roller rockers, home ported heads CFM 216/196,PI 3500 stall
cobra232 is offline   Reply With Quote
Old 09-11-2007, 11:46 PM   #9
4.0 Stang
How much was it?
__________________
[b]C&L Cold Air Intake
Brenspeed 93 Tune
Pypes Muffler Deletes and X Pipe.
MRT Rear Window Louver/ Side Louvers.
GT500 Spoiler
20 % Tint
4.0 Stang is offline   Reply With Quote
Old 09-12-2007, 12:36 AM   #10
sabin_chicago
Send a message via Yahoo to sabin_chicago
good luck and keep us informed
and pics
sabin_chicago is offline   Reply With Quote
60ar, compressor, explorer, hx35y, map, t04b
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
