RE: 96' Mustang 3.8 overheating problem with no heat?
ok, well it must be a head gasket. called up the ford dealer, first thing he said was its a head gasket. $1200-$1500 job.
so i'm going to do it myself. just want to make sure what gaskets should i get, and bolts? use all ford parts?
this will be my first head job. how long should it take me?! anything i should look out for? i am going to buy a ford service manual, the haynes i have sucks!
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
Quote:
ORIGINAL: shawnb
you will need MLS - multi-layer steel - gaskets. Most people here will tell you the only way you do that is get the 99-04 head gaskets. Heck I don't know, I just asked for head gasket kit from O'Reilly's for my '98and the head gaskets were Fel-Pro. Driving on them since and no problems.
Yes get new bolts (about $41 a year ago).
Even with a Haynes manual, I took pictures and drew a diagram of the hoses, lines and wires AND labeled everything. Bag your small parts, bolts and nuts.
I had a machine shop tank and surface my heads, I lapped the valves myself.
I took the hood off to make life easier for me.
I went ahead and replaced the water pump. While doing so I found the heater pipe coming off the pump to be rust frozen in place. even trying to be very careful, it broke off in the pump (at the groove for the o-ring. The new pump was cheap, but the pipe, well $105.00 at the dealership parts store!
Funny part of story: I placed a rag in the intake plenum valley to keep stuff from falling into the block. I was beginning to place everything back on and for some reason I wanted to remove and then replace the lower plenum. Yep, my rag was there! that would have been some mess in the block.
Car is running great since then. Don't know how many miles since my odo gears are broken (another reputation of these cars) but its been more than a year and I put a lot of miles daily driver 50 miles a day Mon-Fri commute.
Quote:
ORIGINAL: shawnb
don't get felpro. they are not as good as ford MLS gaskets.
97 or 98 ford gaskets are fine 99+ ford gaskets are a tad better.
get premium headbolts for the 96. do not use 99 bolts or 98 bolts only use 96 bolts. i reccomend ARP bolts. alittle pricey but the last set i did with felpro were a distaster.
ARP bolts
mls ford gaskets. spray the gaskets with a coating of copper gasket spray and let them get tacky before putting them on. the copper gasket spray really helps seal every little imperfection in the block back up.
you must clean the surface of the block very well and degrease it with starting fluid or brake cleaner
torque to 65ftlbs and you will not have any more problems. you must have the heads resurfaced and tanked with a valvejob and pressure checkedotherwise your just throwing money away as the heads will lift if they are not resurfaced. typically $120-$150 to have the heads redone.
the front accessory drive bracketrs are a pain. there is a stud in the lower front part of each head that will make you find new swear words. there is also a tough bolt behind the powersteering pulley that without pulling the pulley requires you to use a universal joint on an extension. the fuel pressure regulator bolt is a pain. it's on the drivers side head in the back close to the firewall. a 10MM ratchet wrench make the job alittle easier. the dipstick bracket that mounts to the header is soft steel and will tear out easy so soak that header bolt which is double nutted with penetrating oil
get a 15MM 1/2" drive deep well socket for the headbolts and a 4" extension and a 1/2" torquewrench.
soak the header flange bolts that bolt to the Y-pipe real good with PB blaster penetrating spray and go easy on the header bolts as they are screwed into aluminum.
re-assembly. DO NOT TRY TO OVERTORQUE THE INTAKE BOLTS. they are thin and can snap off easily even using a 1/4" ratchet
__________________
current mods
98 3.8L 11psi P1SC Procharger,97 junkyard engine ,3.73`s,7.5 Detroit Truetrac,TA rear girdle,B&M shift kit,2500 stall
mods to complete
8.5:1 ross .030" pistons,Eagle H-Beam 351W rods,Comp cam 224/236 .569"/.578" 112* lobe sep,Rhodes variable duration roller lifters,Pro-M Univer MAF,siemens deka 60lb injectors, upgrade to D1@20psi,Delk Main Girdle and Main studs, Head studs,Comp 1.7 roller rockers, home ported heads CFM 216/196,PI 3500 stall
Well, I'm just another guy having the same no heat-overheating problem on a 96 Mustang GT. I was just curious to know if you've had any problems after you replaced your head gaskets.
Vehicle: 1996 ford mustang/1972 ford mustang mach1
i have a similar issue with a '96 pony . has a 2000 rebuilder engine in it and acts like a headgasket leak . no leaking under car of collant but smokes and loses coolant and runs hot
i started breakin it down and when i pulled the intake off i found the gasket set had failed on the water journals on both sides of front of block.
my question is ..... Would the failed gasket set cause the same symptoms as a head gasket failure????
would save me a load of time and money if i didnt have to break anything else down from here>>
