Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-02-2008, 05:43 PM   #1
95mustang87
Default 95 v6 to 5.0 swap
i am playin on swapping out my v-6 for a 5.0engine. do i need to change to tranny too or would it matter?
__________________
forrest hart
95mustang87 is offline   Reply With Quote
Old 01-02-2008, 06:14 PM   #2
Flake6899
Send a message via AIM to Flake6899
Default RE: 95 v6 to 5.0 swap
You have no idea how much is involved in a swap do you? But to answer your question I belive you just have to swap out the bellhousing. Guys correct me if I'm wrong.
__________________
1999 3.8L 5 Speed
CAI, dual exhaust, SCT xcal-2, 100 wet shot, FRPP 4.10's, auburn posi, Hurst short shifter, Aluminum driveshaft, P&P intakes and heads, SPEC Stage 1 Clutch
2001 SVT Cobra 5 speed
Appearance: Roush Stage 3 front bumper, Roush stage 3 rear spoiler, 18" black saleen wheels, smoked clear corner headlights, chrome bumper inserts.
Performance: SLP o/r x-pipe, Borla Catback, BBK CAI, Comp Cams
Flake6899 is offline   Reply With Quote
Old 01-02-2008, 07:09 PM   #3
MU71L4710N
[align=left]i think u can get away with the bellhousing. anyone thats gonna ask a question like that has no idea what all is involved in changing a v6 into a v8. someone needs to sticky a list or something cuz this question gets asked every day.
found this on another forum: and i wanna say theres more stuff that has to be changed than whats on this list too. its NOT an easy swap and unless you have a donor car your crazy for wanting to do this.
Originally Posted by TennesseeMustangPerf [/align] I am swapping out my fiancee's 1994 Mustang 3.8L with a 4.6L V8, and unfortunately there is not a lot of information on this swap. As I go along with the swap (almost finished, THANK GOD!) I will update this parts list, but or now here is what all had to be swapped out and why. Hopefully it will guide you in deciding if this is the right swap for you, and if so it will assist you in the install. This will also, hopefully, keep you from buying a ton of stuff that you can reuse.
K member- It is believed that the K members are interchangable, this is true between 4cyl., 3.8L V6, and the 5.0L V8, but they are conciderably different on the 4.6L. I originally attempted to modify the K Member to work, but it is completely shaped wrong and DOES require hanging. Your old steering rack WILL bolt right up.
Engine, intake, fuel injector system A/C compressor, coil packs and wires, waterpunp, etc.- Well duh!
Computer- This might not be a requirement, you might get away with a chip, dunno. I had a GT comp, so in she went,
Engine harness- This will have to be changed out for obvious reasons.
Headers- I had to change headers beuase the ones that were on the motor (rown Vic police car) were too small in diameter and the flange hit the firewall.
Transmission- I had to change out transmissions bauase her AOD-E will NOT bolt onto a 4.6L. Thankfully, I had three 4R70Ws lying around. Standard (manual) transmissions should interchange though.
Transmission harness- The harness is the same between AOD-E and 4R70W, but the O2 sensor harnesses are different. You probably can modify your old harness to work though.
Which brings us to O2 sensors. I am not sure what the differences are, but the part numbers for the 3.8L and the 4.6L sensors are different, so I changed them out to be safe. Her old O2 sensors did screw right into the GT pipes though. Again, if using the old trans harness, you can reuse the O2s.
Brake booster- The Modular motors (even the 16 valve GT) will not clear the vacuum booster, so you will need to get a 1996+ GT hydroboost.
Brake booster to steering lines- The booster runs off the power steering pump, therefore you will need to get a set of 1996+ hydroboost and power steering rack lines.
Slight modification of the brake lines will be necessary, as the V6 lines go in from the side, the GT goes into the booster from the bottom.
Transmission tail piece- The ONLY reason why I had to swap these tailpieces out is because the Crown Vic has a larger diameter yoke, therefore the rear seal is too large, and for some reason I cannot get a rear trans seal for a 1996+ GT 4R70W transmission.
Exhaust- Includes intermediate pipe and mufflers.
Radiator- The hoses are in diferent places and are not the same size.
Overflow tank. To match the radiator.
Modification of the drive shaft- The old drive shaft will work, but you will need to either 1. have the shaft shortened approx. 1", or 2, cut off 1" off the yoke. The splines are the same from the V6 and the autos, but the motor pushes the trans. back slightly.
Motor mounts- They are not the same as the V6. I piked up a set of solid motor mounts for a GT for $49.00.
The dash wiring harness does NOT need to be removed for a 4.6L swap, but WILL need to be changed to swap out to a 5.0, as the pins are larger for the computer.
Starters- The starter is the same from a 3.8L to a 5.0, but are different for a 4.6L.
Alternator- Not the same as a 4.6, though 3.8 and 5.0 are the same.
A/C lines- As I stated above, the A/C ompressor is different, and the lines are too.
I have been asked this several times, and yes, fuel lines WILL bolt up the the GT rails. These do not need to be changed out.
I hope this helps out somebody, If I did not score the engine, all accessories, transmission, computer, and wiring harness for $100, and if I did not want to do something TOTALLY different to my fiancee's car, I would NOT have done the swap. This has been a nightmare, and will nickel and dime you to death. A 5.0 liter would have been MUCH easier, but in the end, I think it will be worth it. Good luck if you decide to do it though.
Rob
__________________
mustang wasnt fast enuff so...
Newest Mod:
2008 Yamaha R6
MU71L4710N is offline   Reply With Quote
Old 01-02-2008, 07:17 PM   #4
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
RyansQuick6's Avatar
Vehicle: 02 V6 with some stuff
You can't go off of 4.6 info, the 302 is more similar to the 3.8. They are the same engine but on is missing the front 2 cylinders. The 4.6 is a wide mod motor and completely different.
__________________
Friggin OTards
Quote:
I learned an important lesson in the art of debate. Present your argument clearly, arm yourself with cutting wit and of course, bob and weave!
RyansQuick6 is offline   Reply With Quote
Old 01-02-2008, 07:35 PM   #5
LilRoush
2000 Ford Mustang
LilRoush's Avatar
Vehicle: 2000 Roush
Send a message via AIM to LilRoush
Agreed. People need to just add a super charger and be done with it.
__________________
~Matt
Race car: 2000 Roush #5004
Shark hauler: 2001 Explorer Sport 4.0L
Show car: 1970 Mach 1 351
LilRoush is offline   Reply With Quote
Old 01-02-2008, 09:24 PM   #6
cobra232
Quote:
ORIGINAL: RyansQuick6
no that is completely wrong. the 3.8 is almost as different from the 5.0 as it is from the 4.6
the only thing that the 3.8 essex shares with the 5.0 is lifters and bellhousing. other than that everything is completely different
__________________
current mods
98 3.8L 11psi P1SC Procharger,97 junkyard engine ,3.73`s,7.5 Detroit Truetrac,TA rear girdle,B&M shift kit,2500 stall
mods to complete
8.5:1 ross .030" pistons,Eagle H-Beam 351W rods,Comp cam 224/236 .569"/.578" 112* lobe sep,Rhodes variable duration roller lifters,Pro-M Univer MAF,siemens deka 60lb injectors, upgrade to D1@20psi,Delk Main Girdle and Main studs, Head studs,Comp 1.7 roller rockers, home ported heads CFM 216/196,PI 3500 stall
cobra232 is offline   Reply With Quote
Old 01-02-2008, 09:40 PM   #7
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
Quote:
ORIGINAL: cobra232
I wasn't trying to say they were the exact same, I meant in engineering, being pushrod,and for his years running the swap, since the 5.0 came the 95's too. The bellhousing matching up is a pretty important thing too lol
The best way, as always, to do this swap is to buy a complete donor car, at least complete in the front half. Then swap everything over.
__________________
Friggin OTards
1996, 3850engine, 50, 95, aode, differences, ford, kmember, mustang, swa, swap, transmission, v6, v8, work
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
