How much of a difference is there between Arco and other gas companies??? Cause i use Arco most of the time and i was wondering if it would mess with my engine in the long run. thanks
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
never heard of em[&:]i used name brand, mainly sunoco, but shell and mobile to, for diesel, i go to shell or pride (local) because shell is usually $.15 more a gal[8D]
__________________
2004 Ford F350 6.0 PSD
MBRP 4" turbo back, no muffler/kitty, autometer boost/pyro/trans, SCT X-cal with innovative tunes, MISC appearance, fisher MM2,
ordered: arp head studs, cooling mods, 03 turbo, cfm "small mouth" elbow, ARP head studs, BPD EGR delete
SOLD:
2002 Mustang v6 vert
LTs, catted H, K&N FIPK, SCT X-3 with vmp tunes, misc appearance
ok so maybe i should re question it.....
What is the main difference between a very well know gas company compared to one the it not as well known such as shell or mobile compared to a gas company that only exist in a certain state?
i go to Arco, mainly cause theyre about 18 cents cheaper than all other places. but i dont see any difference or think there would be any difference. the other ones are just more expensive because Arco gets its oil from somewhere else.
ORIGINAL: Matts 85 LX
I have readmany articals about Arcos gas not being nearly as good as most. I use Chevron because it has Techron is it, and its close to me.
Matthew
I live in Ca, and I can tell you first hand, ARCO gas SUCKS!! I cheap out sometimes and go to Arco, and I can tell the different performance wise. Especially when it gets hot, with cheap gas, little ol' sixxer will ping a little! It's not like it's high compression or anything!!
Because one main factor is the cheapest place for gas at a 76 or chevron is $4.51 and at the Arco is $4.40 so should i spend the extra money on the 76 andChevron then the Arco in your guys opinion?
