Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-24-2008, 10:47 PM   #1
lanscapenate10
Vehicle: 2001 Ford Mustang
Default Odd Engine Squeal (not the serpentine belt either)
I just got my 3.8 mustang a couple of months ago and love it. When I bought the car this sound wasn't there but in the last week and a half or so it started. It is a loud squealing sound that is worst when the car is started from cold and quickly quiets once the engine has warmed. And then on regular driving I hear a little chirp or small squeal once every couple seconds. I initially thought it was the serpentine so I quickly replaced the belt (which needed to be replaced anyways), but that didn't solve the problem.
It seems to be coming from the top and front of the engine so I was thinking it might be the water pump and the bearing went out. But the sound is really high pitched and not like any bad bearing sound I've ever heard. Plus the car only has 55,000 miles and water pumps should be replaced around 100,000, so I wasnt entirely sure.
Any thoughts would be great. I already looked through the threads and posts and nothing really helped. Thanks
lanscapenate10 is offline   Reply With Quote
Old 09-24-2008, 10:56 PM   #2
cuban tech
1999 Ford Mustang
cuban tech's Avatar
Vehicle: 1999 Mustang
Send a message via AIM to cuban tech
it's the cam synchronize on the top of the engine
__________________
Ford Certified Tech
Land Rover Certified Tech
Ase Certified Tech
Honda/ Acura Certified Tech
AllData Automotive Information Specialist
1999 3.8 V6
35th Anniversary Edition, 4R70W trans
Performance:
BBK Cold Air Intake
True Dual Exhaust
cuban tech is offline   Reply With Quote
Old 09-24-2008, 11:05 PM   #3
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
RyansQuick6's Avatar
Vehicle: 02 V6 with some stuff
alternator? Tensioner? Idler? Remove the belt and spin them and see if they drag at all
__________________
Friggin OTards
Quote:
I learned an important lesson in the art of debate. Present your argument clearly, arm yourself with cutting wit and of course, bob and weave!
RyansQuick6 is offline   Reply With Quote
Old 09-24-2008, 11:12 PM   #4
lanscapenate10
is that the cam position sensor?
Old 09-25-2008, 01:05 AM   #5
cuban tech
1999 Ford Mustang
cuban tech's Avatar
the synchronize is right below the cam sensor. if you want you can run the engine when it cold and listen for the noise and use a long screwdriver and place it right on the cam sensor and listen if the noise is from there. RyansQuick6 is also right it could be from there.
__________________
Ford Certified Tech
Ase Certified Tech
1999 3.8 V6
Performance:
BBK Cold Air Intake
True Dual Exhaust
Old 09-25-2008, 12:08 PM   #6
mustangman02232
mustangman02232's Avatar
Vehicle: 04 F350 6.0
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
id start with the alt, ps pump, idler and water pump first.
__________________
2004 Ford F350 6.0 PSD
MBRP 4" turbo back, no muffler/kitty, autometer boost/pyro/trans, SCT X-cal with innovative tunes, MISC appearance, fisher MM2,
not installed: arp head studs, cooling mods, 03 turbo, cfm "small mouth" elbow, ARP head studs, BPD EGR delete
SOLD:
2002 Mustang v6 vert
LTs, catted H, K&N FIPK, SCT X-3 with vmp tunes, misc appearance
RIP tripsevn7
4/1/77 - 7/27/08
mustangman02232 is offline   Reply With Quote
2002, 38, 73, belt, bullitt, cold, diesel, driving, engine, ford, mustang, serpentine, sound, squeal, squealing, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
