Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-15-2008, 08:28 PM   #11
ezekiel90
ezekiel90's Avatar
Vehicle: 96cobra, 01 v6
thats funny because all my friends have trucks that are faster than my car haha. Powerstroke deisels, turbo Cummings 2500's and 3500s. The fastest one is a ram 2500 turbo cummings deisel thats making 900hp and 1260ft-lbs. it scares the bajeepers out of me.
__________________
ezekiel90 is offline   Reply With Quote
Old 10-15-2008, 10:47 PM   #12
torchred02
Vehicle: 2002 ford mustang
get some 4 10s in that thing
__________________
torchred02 is offline   Reply With Quote
Old 10-15-2008, 10:54 PM   #13
mustangman02232
mustangman02232's Avatar
Vehicle: 04 F350 6.0
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
Quote:
my work truck is a 96 f350 with a 9' dump body, with banks chip, down pipe, exhaust, I/C, turbo upgrade, trans command, and propane injection, the fugger is fast
and LONG TUBE headers made a big differance on my car
__________________
2004 Ford F350 6.0 PSD
MBRP 4" turbo back, no muffler/kitty, autometer boost/pyro/trans, SCT X-cal with innovative tunes, MISC appearance, fisher MM2,
not installed: arp head studs, cooling mods, 03 turbo, cfm "small mouth" elbow, ARP head studs, BPD EGR delete
SOLD:
2002 Mustang v6 vert
LTs, catted H, K&N FIPK, SCT X-3 with vmp tunes, misc appearance
RIP tripsevn7
4/1/77 - 7/27/08
mustangman02232 is offline   Reply With Quote
Old 10-16-2008, 02:05 PM   #14
GUESTPROUSER
Vehicle: 1997, Ford Mustang V6
Quote:
Originally Posted by koolkat13838 View Post
For real ^^^ ()() <----that is the tennis ball I threw
\/ ducks
GUESTPROUSER is offline   Reply With Quote
Old 10-16-2008, 03:17 PM   #15
GUESTPROUSER
Talking
Quote:
Originally Posted by jthorn9 View Post
Read my edits to your list.
Every morning I wake up and begin to walk toward this bodacios red 97 - dual exhaust - racing stripped - beauty, it reminds me of when I walked for my high school diploma. Siyanara folks! I'm gone!
............. Ok, I'm back from dreaming....
Seriously though, these cars are the bomb, I'm hooked! The only car in the world I've found to match this car in looks, design, safety, and built for pure speed is the Bugatti, and its 2.? millions! They haven't been able to find a better design than the mustangs after all these years. Look and see for yourself.
Here's the King of the Road
Here's the Alien from Mars, lets call him Predator - Out of the reach of the average man. Dual V8's! 2 mill+ and so on....
Take some time about 12 minutes and see the video of the Bugatti for yourself. I'll let that car beat me any day and eat my breakfast.
If you hear a stang, your day has been declared wonderful
If you see, hear and touch but not ride a stang your lucky
But if you own a stang, then you are just 'blessed'....
Old 10-16-2008, 03:47 PM   #16
GUESTPROUSER
Post
Car: 1997 Ford Mustang V6 3.8L
Exhaust
Intake
Tuner
Pulleys
Suspension
Brakes - Cobra conversion brake kit
Super Charger - Connect when using, disconnect when not using?
I will stick with these mods since we all agreed on it and gas mileage will be the same as before, I hope . And do as said and add the super charger that can easily be disconnected?
Questions:
1. Just wanna know if were all on the same page. After all this is done, I just want to focus on detailing, but whats looks without power . Is what I said above what we all agreed on, xing out the other junk i thought of like #1's and 2?
2. Can the super charger really be disconnected/disabled and reconnected when I'm ready to use it?
3. I was looking at websites like the one below and I'm baffled. I honestly don't know which brand tuner, which type suspension, etc..
http://www.autopartswarehouse.com/mo...makemodel.html
Which site do I buy each of these parts from and what are the names of each part? I want to be able to just bring my debit card and start buying each one? So direct links to the exact part would be nice..
I'm currently living in the Bahamas so I can't be mistakingly buying the wrong part or brand like I'm back in the Florida.
4. How much horse power will I have after all of these mods?
Thanks allot!
Mustang Forums is the BEST!
Old 10-16-2008, 08:55 PM   #17
jthorn9
CSMG Moderator
jthorn9's Avatar
Vehicle: 1995 Mustang GT, 2000 Mustang
No, the S/C isn't disconnected. S/Cs work like this (bear with me, this will be a long post).
OK, there are two types of S/Cs:
*) Roots based - roots based S/Cs can either be single or twin screw S/Cs. These S/Cs replace the upper intake manifold (and in some cases require an adaptor bracked, or special lower intake manifold). Examples of these S/Cs are the single screw M-90 (used on the old single port TBirds which can be adapted to 94-98s), the twin screw M-112 (used on the 03/04 Terminator Cobras, and can be adapted to the 99-04 Mustangs), and the twin screw Kenne Bell (which is a whipple S/C that produces massive loads of mid range power, not sure if a V6 adaptation was ever made).
Roots based S/Cs spool up between 1500 rpms and 4000 depending on the model. In, short, they're good at making great off the line power that last through 3rd gear, but you'll begin to experiance lag in higher gears. The Kenne Bell S/Cs aren't as badly effected, but they still lag out.
Spooling - then range/RPM in which an S/C makes power. Stay under this and the amount of air forced into the intake is minute (similar to stock) and doesn't affect MPG. Go above this and the S/Cs ability (or efficiency) begins to can out and you'll experiance a short bit of lag in higher gears, and just before shifting in the low gears.
*) Centrifugal S/Cs - centrifugal S/Cs mount off to the side of the engine and look similar to a turbo. They can force larger sums of air at any given PSI than a roots based S/C (making them more effecient), however they have a slight lag time in spooling as they start spooling at around 2000-2500 RPMs, but spool upwards of 5000 RPMs (which is the approx powerband for most stock/mildly moded cars). Vortech, Procharger, and Paxton are all examples of centrifugal based S/Cs.
__________________
Trinity 99 Mustang SVT Cobra
Selena 95 Mustang SVO GT-40 1.5L 11PSI Kenne Bell Supercharger
jthorn9 is offline   Reply With Quote
Old 10-16-2008, 08:58 PM   #18
jthorn9
CSMG Moderator
jthorn9's Avatar
Oh, and S/C usually adds between 9-11 hp per PSI. So a 9 psi S/C will add beween 81-99 rwhp (depends on S/C effeciency, timing effect on power, engine condition, and several other variables).
Tuners will net around 10 rwhp with a good tune.
Exhaust will net around another 10 rwhp.
CAIs can not be used with centrifugal based S/Cs, but can be used with roots based (but aren't very effective at adding hp). They'll add around 2-4 rwhp stock.
__________________
Old 10-18-2008, 10:10 PM   #19
wmrcer
Intake, exhaust, 4.10s with posi, an stall the damn automatic.
__________________
2000 3.8 5spd
H/C/I
4.10 gear
bolt ons
225 Hp/220 TQ n/a
wmrcer is offline   Reply With Quote
Old 10-19-2008, 12:54 AM   #20
LilRoush
2000 Ford Mustang
LilRoush's Avatar
Vehicle: 2000 Roush
Send a message via AIM to LilRoush
Just curious, where did those ranges come from?
Sixer M112 blower set ups are seeing 13 to 18 hp per psi (depending on rpm), and those are known for being parasitic.
__________________
~Matt
Race car: 2000 Roush #5004
Shark hauler: 2001 Explorer Sport 4.0L
Show car: 1970 Mach 1 351
LilRoush is offline   Reply With Quote
mustang, powerstroke, sct, work, xcal
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
