And where shall one find these Goerlich Xcelerators?
**Nevermind, found the website.**
they are really a good muffler but quiet with stock cats and full exhaust. not bad with stock cats and dumps and really nice with offroad pipes or high flow cats
if you found a site that sells them post it up
__________________
current mods
98 3.8L 11psi P1SC Procharger,97 junkyard engine ,3.73`s,7.5 Detroit Truetrac,TA rear girdle,B&M shift kit,2500 stall
mods to complete
8.5:1 ross .030" pistons,Eagle H-Beam 351W rods,Comp cam 224/236 .569"/.578" 112* lobe sep,Rhodes variable duration roller lifters,Pro-M Univer MAF,siemens deka 60lb injectors, upgrade to D1@20psi,Delk Main Girdle and Main studs, Head studs,Comp 1.7 roller rockers, home ported heads CFM 216/196,PI 3500 stall
yeah usually you have to find an exhaust shop that sell them. check out the clip i posted of the magnaflows. i wish i had a clip of mine but they really sounded almost identical.
__________________
current mods
mods to complete
so i have a stupid question. is a 4.2 or 4.3 just a stroked out 3.8? and what are the performance numbers like? what is needed for the whole "change" for lack of a better word. I'm unfamiliar with storked engines and stroking an engine. just curious
Yessir...
A 4.2 is a stroked 3.8,
and a 4.3 is a stroked and bored 3.8...
All u need is a stroker kit technically...
But a cam wouldn't hurt...
Neither would a port and polish job...
And I'm goin for true duals with dumps...
I don't really care so much about sound as performance,
though I would really rather it not sound like ****,
performance is more important than sound imo...
If the goerlichs can match magnaflows in performance then I'll go with em...
If not then I'd prefer magnaflows...
My setup isnt a 4.2L but it might be able to help you still.
I run a 94/95 GT (5.0) BBK O/R X-pipe that a muffler shop modified for me ($70 dollars.)
They just changed the flange size from 2.5 to 2.25" and slightly altered the angle. Works like a dream (Craptastic quality video of it www.youtube.com/CrainRacing )
Any 94-04 midpipe will be able to be modified to work with the sixer exhaust for a decent price. 94/95 have to have the angle altered less so it might be more cost friendly to purchase what you need from that year range.
