Ryan how is the termi tank going? I havent decided if I want to do that swap when I finish the engine or if I want to go with the Aeromotive return style fuel system.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
2003 Oxford White Cobra #3328 of 8394
Apten ported m112, 2.93, 6lb lower, Metco idlers, JLT Pipe, SCT 90mm MAF, 60lb injectors, Kenne Bell Boost-a-Pump, Mac Longtubes, Flowmasters, Evenflow cooling mod, LFP Dual pass heat exchanger, MGW short throw, Cobra Bob's Shifter Gasket
Eibach Pro-kit, UPR SFC's, Billetflow IRS Brace, UPR clutch quadrant and firewall adjuster www.tnmustangclub.com
Tanks working great, even with the v6 style setup wedged in there. I'm most likely upgrading to aeromotive as well, but after some careful research, it's not necessary, truly overkill. A Termi tank and hat with twin pumps, be them Supercar, svt focus or whatever is enough. Screw the BAP, I'm just gonna hook the fuel pump feed to a relay and then tie that directly into the pump/pumps.
I'm offshore so this is the first post I've made in 2 weeks, but I'll post up some details of some things I've been working on while out here, some of them pretty damn neat. I'll give you a hint...
.... 1.37sec 0-60, 1.30 sec 60' time.
__________________
Friggin OTards
Quote:
I learned an important lesson in the art of debate. Present your argument clearly, arm yourself with cutting wit and of course, bob and weave!
