I would love to throw an M112 on my mustang, and want to start saving for one however I think there are alot of supporting mods I should do first, mainly better brakes and suspension. However I lack the extensive knowledge you guys have. And thats crazy that you designed this kit, I could not even begin to fathom taking on a project like that. So do you have to search around for a used M112 off a cobra since noone reproduces them?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
I have a diablo tuner but im pretty sure that wont be able to tune for a supercharger lol. However there arn't any other mods needed I just feel like if I'm going to supercharge my car I should upgrade the brakes and suspension a little to handle the extra power, probably the rear end too. And I assume its a pretty indepth swap, alot of things I'm not familiar with in there. I was looking at my engine the other day just to learn and stuff and I was thinking, wow, I dont even know where I would start to swap the intake because there is so much stuff like vaccuum lines, hoses, and things like that.
as far as mpg, i believe i can safely have the #1 spot for biggest drop. before i saw around 27mpg and after i saw about 13mpg lol....but that was my own fault. i have since found some things that went way wrong causing my mpg to drop.
__________________
2003 Oxford White Cobra #3328 of 8394
Apten ported m112, 2.93, 6lb lower, Metco idlers, JLT Pipe, SCT 90mm MAF, 60lb injectors, Kenne Bell Boost-a-Pump, Mac Longtubes, Flowmasters, Evenflow cooling mod, LFP Dual pass heat exchanger, MGW short throw, Cobra Bob's Shifter Gasket
Eibach Pro-kit, UPR SFC's, Billetflow IRS Brace, UPR clutch quadrant and firewall adjuster www.tnmustangclub.com
Do tell....so no one else makes the same mistake. Sorry about your loss (in MPG)
if i wanted to do an h/c/i swap and ultimately m112 just like everyone else here, would it be better to get a mild cam that would work before and after f/i or just wait and get the big stuff but put it all together at once? if that makes sense..
