Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-09-2009, 08:48 AM   #1
tightdogal
Send a message via AIM to tightdogal
Question Blown Cigarette Lighter Fuse?
Hey guys, I need some help. The other day I was using an electronic air pump to pump one of my tires because I had a flat. It gets power from the cigarette lighter, and I let it pump for about 20 mins. Suddenly, it shut off, and now whenever I use my cigarette lighter for anything (phone charge, ipod charger, even the basic cigarette lighter itself) nothing happens. So I think I blew a fuse.
Can someone guide me how which fuse it is and where to look? I want to do this myself, is it easy enough to just simply buy another fuse and bam, done?
Thanks!!!!
__________________
2000 Mustang V6
-yeah, its fast. compared to a jetta.
tightdogal is offline   Reply With Quote
Old 01-09-2009, 08:51 AM   #2
99BlackPonyGT
aka Negative Nancy
Vehicle: 1999 Mustang GT
Send a message via AIM to 99BlackPonyGT
look in owners manual or on the fuse panel *maybe, its there on my other cars, but my stang doesnt have a panel so who knows* then buy a new fuse of the same size, and put it in...done....takes 10 seconds if you know which fuse to pull
99BlackPonyGT is offline   Reply With Quote
Old 01-09-2009, 08:55 AM   #3
99BlackPonyGT
aka Negative Nancy
this is for a 99 gt but i dont think yours will be any different than mine
so buy a 20A fuse and pull the one out and put the new one in....there should be a puller tool attached to the fuse panel, but if you dont have that, needle nose pliers work too
Old 01-09-2009, 10:07 AM   #4
tightdogal
This diagram is exactly what i was looking for! Thanks!
yeah it doesn't have the fuses in the owners manual. I checked. I'll try this out and see if it's the problem. Idon't know what else would cause it to stop working other than that.
__________________
2000 Mustang V6
Old 01-09-2009, 10:31 AM   #5
99BlackPonyGT
aka Negative Nancy
no problem....air pump blows the fuse in my car sometimes too... the fuses are sold in packs of like 5 so just hold onto them...dont go with a bigger fuse though, stick with what came in it
Old 01-09-2009, 09:04 PM   #6
alkureg
2003 Ford Mustang
alkureg's Avatar
Vehicle: ...
i always looked under the lid of the fuse box, not the manual
__________________
[vigilante performance]
alkureg is offline   Reply With Quote
Old 01-10-2009, 12:35 AM   #7
JOE2391
2004 Ford Mustang
Vehicle: 2004
Send a message via AIM to JOE2391
if the fuse isnt blown put a plug into the cigarette hole and spin it the wire might be messed up that happened to me and it work just fine after that
__________________
JOE2391 is offline   Reply With Quote
Old 01-10-2009, 02:54 AM   #8
TurtleSLow
2000 Ford F-350
My Garage
its in there trust me. look at the back of the manual in the glossary and look up "Fuses" and it will show you the page number. but yeah its the same diagram posted above
i have a question for you all kinda related to this, only one of my power ports works. so its not the fuse. it just stopped working one day while the other one stayed working.
its the one under the radio, not the one by the coin holder. took the panel off and the wire seems to be fine but it doesnt get power
__________________
LT's, o/r h, flow 40's exhaust clip http://www.youtube.com/watch?v=Y8cSdoJBST4
14.607 @ 94.52 2.185 60ft crappy street tires
TurtleSLow is offline   Reply With Quote
Old 01-10-2009, 10:14 AM   #9
JOE2391
2004 Ford Mustang
Vehicle: 2004
turn it !! i had the same problem turn it plug somthing in to it turn it alil c if it kicks on just keep turning let me kno if that works it happened to me like 3 times
__________________
Old 01-10-2009, 10:36 PM   #10
mustangman02232
mustangman02232's Avatar
Vehicle: 04 F350 6.0
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
pull em out and check how the hell you been josh we havent seen you around in a while?
__________________
2004 Ford F350 6.0 PSD
MBRP 4" turbo back, no muffler/kitty, autometer boost/pyro/trans, SCT X-cal with innovative tunes, MISC appearance, fisher MM2,
not installed: arp head studs, cooling mods, 03 turbo, cfm "small mouth" elbow, ARP head studs, BPD EGR delete
SOLD:
2002 Mustang v6 vert
LTs, catted H, K&N FIPK, SCT X-3 with vmp tunes, misc appearance
RIP tripsevn7
4/1/77 - 7/27/08
mustangman02232 is offline   Reply With Quote
2003, 2004, 2005, 2007, blown, car, cig, cigarette, cigarette lighter, fuse, jetta, lighter, mustang, ports, power, work
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
