You'd come out about the same if you got a local shop to actually do the build if you buy all the pieces from SSM, but I'd rather let Tom slap it all together, since he knows those things inside and out.
I'd recommend upgrading to an 01+ block as well. If you can swing the cash, get that race prepped crank option too!!!!
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
Friggin OTards
Quote:
I learned an important lesson in the art of debate. Present your argument clearly, arm yourself with cutting wit and of course, bob and weave!
well i plan on having them do the stage 3 heads instead of the stage 2 b/c i want to get the most out of the engine while the window is there. i'll prob get a windstar i dont know if it can take the turbo. but the site says...
Long Rod” 4.3 stroker crate engines are the simple bolt-in solution to your performance andreliability needs without V8 engine swap expense and hassles. These are complete engines,not just a long block. Dyno-proven to over 550 horsepower, these engines can be tuned toproduce 280-390 horsepower naturally aspirated. “Long rod” engines feature 8.7-11.5:1 compressionratio, seasoned 99-04 3.8 block, new Ford 4.2 crank, SCAT forged 351/408W strokerH-beam rods, ARP rod bolts, Wiseco forged pistons, Stage 2+ PowerPak, SSM CompCamsbillet cam and stud mount 1.7 roller rockers, CompCams hardened pushrods, main studs, girdle,proper oil pan, pickup, dipstick, balancer, and flywheel/flexplate. Professionally neutralbalanced, machined, torque plate honed, aligned, decked, glyptaled, and assembled.
__________________
2000 Ford Mustang Convert.
BBK CAi
BBK Headers about to be mac LTs
True Dual Exhaust
Ram HDK Clutch
Spec Billet Steel Flywheel
Screaming Demon Coil /Live Wires
Sct SF3 Tuner 93 performance tune
Upcoming UPR short throw Shift
He doesn't need a "race prepped crank" look at _J_'s car...
__________________
Block .20 Bore 3.830, ARP Head Studs, Ford Girdle, Scat 4340 Forged 6.125" H-Beam with Ross Forged Dished Pistons 8:7:1 compression, KPP Cam Reground 224* .587" Intake / 222* .567" Exhaust 114 LCA, 110 IC, Self Ported Heads with Self Ported Upper intake ported lower intake with a matching ported throttle, Mac long tube headers, Flow master 40 series mufflers, 3.73 motive gears, Eaton posi trac, Sct livewire, Bilstien shocks and struts, Eibach pro kit springs. FS: POLISHED VORTECH V2 3.8L KIT
Well the option didn't exist when his was built. I'm considering it, but not sure yet. I've been looking at some windage tray options, which he offers, that will pretty much eliminate the need for the "race prep". I'm gonna just buy the 4.3 rotating assembly and get the "balancing" option. That should do fine with my setup
__________________
Friggin OTards
There are still more things you can upgrade, metal supercoupe lifter guides, compcams hydraulic high rpm lifters(part # 851-16), Comp titanium retainers, you could even switch to 8mm valves, but the gains are not worth the effort or cost(from what I read, I read a lot lol).
As for the price v/s ordering a shortblock you can use me as an example, It has cost me $3060 for my shortblock, and that's with a 02 block.
__________________
XX Under Construction XX
No longer a 232
Sure it did, with the money _J_ has spent on his car anything was an option for him pretty much. He could have found a shop to micropolish/shot peened/cryo treated and whatever else he wanted
__________________
so when i upgrade the suspension what all should i buy like the kits that cost 2k? thats comes with everything. and what type of tranny would i need i know some sites have the t-5 at 500 hp/tq rate. and i guess im going to buy the 8.8 rear end off ebay of a gt.
__________________
BBK CAi
True Dual Exhaust
Ram HDK Clutch
