Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 02-25-2009, 04:19 AM   #1
troy81
Vehicle: 2002 Ford Mustang
Default why dont they put M90s on 99-04s?
if you make an upper intake adaptor like they use for the m112 wouldnt the m 90 be about the same setup, obviously less boost but... has this been done? i cant find any threads i kinda suck at searching, i looked on google and there were a couple that were unclear and none were using intake adaptors. like instead of using the super coupe intakes which are
single port you could just make an adaptor for the split port. with that i would think that would make some good power for not too much money. idk maybe im missing somehting, lemmi know
troy81 is offline   Reply With Quote
Old 02-25-2009, 06:37 AM   #2
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
RyansQuick6's Avatar
Vehicle: 02 V6 with some stuff
split port, which is far superior to m90 single port
__________________
Friggin OTards
Quote:
I learned an important lesson in the art of debate. Present your argument clearly, arm yourself with cutting wit and of course, bob and weave!
RyansQuick6 is offline   Reply With Quote
Old 02-25-2009, 08:58 AM   #3
amrcnidyot
if you use the m90 you will most likely need an intercooler. that is where the main problem is. the m112 is big enough that it doesnt really need it on our little engines. that and its really not much more for an m112 than it is for a m90
__________________
amrcnidyot is offline   Reply With Quote
Old 02-25-2009, 10:24 AM   #4
nitrous36
nitrous36's Avatar
Becuase you have to swap to the older heads and fuel system. Taking a step back, to take a step forward and only gain about 30 hp isnt worth it. In this case with all the work involved.
__________________
2000 Atlantic Blue 3.8 V6
- Procharger - 11lb pulley
- SCT XCAL 2 tuner
- Forged internals
- P&P heads
- 2800 stall torgue converter
- Pacesetter H pipe
- Magna Flow Dual Exhaust
- BBK Strut Brace
- Detroit Truetrac LSD
- GT Bumper
Coming next: Maximum Motorsport Subframe connectors, swap to 15lb pulley
nitrous36 is offline   Reply With Quote
Old 02-25-2009, 11:08 AM   #5
ooterman
2001 Volkswagen Jetta
My Garage
ooterman's Avatar
The only reason to go M90 is if you have a single port 95-98 sn-95 and want to go F/I without doing a split port change and then going the m112 route.
The difference between the single to split is around a 40hp difference. Thats why the 99-04s have a high hp stock then the 95-98s.
__________________
1997 3.8l V6 Convertible
Upgrades:
Magnaflow Single Catback
American Muscle Cold Air Intake
ooterman is offline   Reply With Quote
Old 02-25-2009, 01:10 PM   #6
troy81
Quote:
why? wouldnt the split port still hookup to its own heads just fine?
Ryan, no offense but idk what that means
Old 02-25-2009, 01:26 PM   #7
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
the single port and split port design haas to do with the heads. The 99+ has the split port design which gives 40hp. The intakes have to be different to mate up to the different heads. An M90 was design to bolt to the single port intake, so if a new edge were to run it they would have to slap on older poorly flowing heads to do it and lose power.
__________________
Friggin OTards
Old 02-25-2009, 01:28 PM   #8
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
look at this link and you'll see the difference in design
__________________
Friggin OTards
Old 02-25-2009, 09:23 PM   #9
troy81
well i completely understand the split port vs single port thing but im saying if you made an upper intake to go from the m90 to the split port like the way the m112 adaptor does than i dont see why you would HAVE to run a single port. are you saying this because the m90 and upper intake are one piece? i think we might be misunderstanding each other
Old 02-25-2009, 09:39 PM   #10
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
The whole M90 on a splitport is just an inferior setup, especially compared to the M112.
I see what you're saying though, the same could be said for slapping a roushcharger on there since it's based off of the M90.
__________________
Friggin OTards
1997, 38, m90, mustang, upgrade
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
