Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-10-2009, 08:33 PM   #1
SuPa StaLLiOn 7
2000 Ford Mustang
Vehicle: 2000 Ford Mustang V6 Convertible
Send a message via AIM to SuPa StaLLiOn 7
Default My car sounds like crap
Today I had my heat on and it was doing the usual surge with it on. However, I'm starting to hear the car make ticking/clicking noises when it's in park. Any ideas?
__________________
-K&N CAI
-17" Cobra R silver wheels
SuPa StaLLiOn 7 is offline   Reply With Quote
Old 03-10-2009, 10:19 PM   #2
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
RyansQuick6's Avatar
Vehicle: 02 V6 with some stuff
passegner side exhaust manifold collector is most likely cracked. It's not terribly difficult to remove, it just takes a little time. You'll need to have it re-welded, and when you do, have them fill the seam entirely
__________________
Friggin OTards
Quote:
I learned an important lesson in the art of debate. Present your argument clearly, arm yourself with cutting wit and of course, bob and weave!
RyansQuick6 is offline   Reply With Quote
Old 03-11-2009, 01:59 AM   #3
ezekiel90
ezekiel90's Avatar
Vehicle: 96cobra, 01 v6
Quote:
thats what situation im in. it was cracked when i got it, now its cracked again after i had it welded a year ago. is there a permanent solution?
__________________
ezekiel90 is offline   Reply With Quote
Old 03-11-2009, 07:38 AM   #4
moontang
moontang's Avatar
Vehicle: 2004 VEE****INGSEXY
Send a message via AIM to moontang
Aftermarket Headers or don't run your AC or both
moontang is offline   Reply With Quote
Old 03-11-2009, 10:30 AM   #5
StangKid018
And if your not into spending big bucks for new headers to replace those old ones you can find some 98 headers which are slightly bigger which you could benefit from the old ones with less cost then buying new ones.
__________________
2004 Mustang 3.9L
1998 Cobra 8.8 Rear End, 3.73s
CDC Shaker Intake System
K&N Filter /w Removed Silencer
American Thunder Flowmaster Original 40s
MAC Longtube Headers
MAC O/R H-Pipe
17x8 Arcathite Bullits
Mach 1 Chin Spoiler / Grill Delete / GT Fogs
StangKid018 is offline   Reply With Quote
Old 03-11-2009, 12:45 PM   #6
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
The permanent solution is literally to just have the entire collector seam welded instead of jsut repairing the crack on the tube. The reason the crack develops is from when the car is turn off and the a/c is still dripping, after the engine cools water collects in the manifold seam. When the engine is started and warms up, so does the water, and it expands, causing the crack.
__________________
Friggin OTards
Old 03-11-2009, 02:42 PM   #7
stangant
stangant's Avatar
Vehicle: 2000, ford, mustang
Send a message via AIM to stangant
also extend the ac hose to the side so it will stop leaking.
__________________
Car Domain
Money doesn't make me happy, its all the car parts that the money buys that does!
stangant is offline   Reply With Quote
Old 03-11-2009, 07:17 PM   #8
SuPa StaLLiOn 7
2000 Ford Mustang
Thanks for the help Ryan, once this weather gets a bit warmer I'll be sure to check it.
__________________
-K&N CAI
Old 03-11-2009, 08:30 PM   #9
ezekiel90
ezekiel90's Avatar
i almost NEVER run the AC, never have to, Southern California weather :]. but yea ill look into getting '98 headers. They swap in there like a glove right?
__________________
Old 03-11-2009, 10:38 PM   #10
SuPa StaLLiOn 7
2000 Ford Mustang
Here in NYC I have the auto-start. In the winter I start the car ten mins before I go in and it's still cold. This past summer we had a week of 100+ degrees and I had no A/C. My refrigerant hose was done and I suffered with my top down. I was on the highway coming home from school doing 80 with the hottest wind ever. It was absolutely disgusting; when I got my A/C I usually use it when it's like 90+ or raining. If it's nighttime, top down is the way to go, I love at night. Off-topic, yes I know...
__________________
-K&N CAI
car, cracked, crap, manifold, mustang, sounds, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
