Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 05-20-2009, 06:34 PM   #1
Jigsaw07
2000 Ford Mustang
Vehicle: 2000 Ford Mustang V6
Default Few maintenance questions
Well it's time to change the plugs and wires on my stang, just not sure what to buy. Obviously I know plugs and wires lol, but what brand should I go for? Is there even a difference from OEM? Also please excuse my noobness but do I have to buy a coil pack separately? and do I have to change the coil pack if it doesn't come with the plugs and wires? I'm at 98k miles, got the car with 95 and have no clue whats been done before so I was wondering if there was anything else I should look into replacing? I've already changed the air filter, seafoamed the car, cleaned the IAC and the MAF as well. Thanks in advanced for all the help guys!
__________________
Jigsaw07 is offline   Reply With Quote
Old 05-20-2009, 06:51 PM   #2
ayrton02
ayrton02's Avatar
Vehicle: 2002 Ford Mustang
Change the fuel filter, check the brakes/pads/rotors (replace if necessary), check the hoses (replace if necessary), check the drive belt (replace if necessary), new brake fluid, new rear end fluid, new tranny fluid, new coolant. Get 8.5 MSD wires and Autolite coppers or Motorcraft replacements. Keep the coil, you don't have to change it. You're not going to get any noticeable hp or mpg gains from plugs, wires, and a new coil on a stock car... so don't believe otherwise.
DO NOT get any Bosch plug... platinum plugs are a waste too. If you want a high dollar plug, Denso or NGK Iridiums are the way to go.
__________________
2002 3.8 V6 Mustang - MAC Longtubes, MAC o/r H-pipe,
Flowmaster Super 40s, BBK cai, SCT X-Cal 3, Eibach Pro-Kit,
Maximum Motorsports C/C plates, GT rear sway bar, front/rear
Mach 1 brakes
Quote:
Originally Posted by simpsonfan13 View Post
LS1>scramjet
the new scramjet is not the new gto
ayrton02 is offline   Reply With Quote
Old 05-20-2009, 07:14 PM   #3
Jigsaw07
2000 Ford Mustang
Well the reason I was considering changing the coil pack was because I'm currently experiencing a miss fire and I heard that could be the problem.
__________________
Old 05-20-2009, 07:21 PM   #4
JKs95stang
Quote:
Change the wires and plugs and everything else, then see if it runs better. I bet it will, coilpacks usually last quite awhile, if it is bad, get a ford oem CP. GL
JKs95stang is offline   Reply With Quote
Old 05-20-2009, 07:21 PM   #5
ayrton02
ayrton02's Avatar
Do the plugs and wires, that should take care of it. It's probably a bad wire. It'll save you like $100 not to get a coil and IF it is bad, you can change it in like 10 minutes without having to redo the plugs and wires.
__________________
Mach 1 brakes
LS1>scramjet
2, 2007, bosch, ford, maintanence, maintenance, mustang, platinum, questions, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
