Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-03-2009, 04:29 PM   #1
herrbreit
Vehicle: 1996 ford mustang/1972 ford mustang mach1
Default coolant loss in a '96 pony
picked up a '96 pony for oldest daughter
driving home she over heated and i had to trailer her in.
symptomatic of a headgasket leak.. ie no coolant seen leaking under car , smoking
when i pulled the intake i found that the gaskets on the front water journals had failed . would this cause symptomatic problems similar to head gasket
would save me time and money if i dont need to pull the heads.
visually the heads look good as is.
engine is a 2000 rebuilder with a sticker sayin so on valve covers. 3.8L v6
can i do a compression test some how with a socket wrench and a tester ?
thx in advance
herrbreit is offline   Reply With Quote
Old 07-04-2009, 07:53 AM   #2
moontang
moontang's Avatar
Vehicle: 2004 VEE****INGSEXY
Send a message via AIM to moontang
well if it were me i would replace the gaskets that you know are bad now unless you can see where there is fluid from the head gasket externally to me it would seem logical to leave the heads alone as its a newer engine the split ports dont have problems with the heads like the 94-early96's
__________________
Quote:
You're the one who has to live with a stick-figure black man banging your forehead.
2004 3.9L v6 k&n, l/t's, o/r h, slp lm1, roush springs, spec st2 clutch, strut tower brace, mildly built t-5, adj clutch, hurst SST
1988 olds cutlass supreme 307 bone stock
moontang is offline   Reply With Quote
Old 07-04-2009, 09:11 PM   #3
jthorn9
CSMG Moderator
jthorn9's Avatar
Vehicle: 1995 Mustang GT, 2000 Mustang
Head gaskets are prone to failure in 94-early 96 V6 models, I'd change them just to be sure. I think you probably found the problem and it should be good to good, but on the same token, you still can be sure theres not a minor head gasket issue.
__________________
Trinity 99 Mustang SVT Cobra
Selena 95 Mustang SVO GT-40 1.5L 11PSI Kenne Bell Supercharger
jthorn9 is offline   Reply With Quote
Old 07-08-2009, 11:20 PM   #4
herrbreit
bad news is i got it back together and im still losing coolant thru the exhaust.
good news is oil isnt geting any coolant in it .
time to rip it apart and redo the headgaskets and check the heads . thx for your input guys appreciate it wish me luck on my adventure
Old 07-09-2009, 11:23 AM   #5
jthorn9
CSMG Moderator
jthorn9's Avatar
Yea, you have a small leak between a coolant port and the cylinder.
__________________
Old 07-13-2009, 09:04 PM   #6
herrbreit
with anyluck i wont have to get new intake gaskets and ill be able to fix it for under another 150bux
paid 1800 for for the car and have another 300ish in replacement parts
plus 150 for headgaskets and bolts
all i need now is a tarnny gasket and filter change and its road ready once i get my lazt arse back into the engine bay
Old 07-13-2009, 09:06 PM   #7
herrbreit
best price i found on anything close enough to look at was 3grand so im not unhappy
altho i might buy a 2k1 model this week for 1500 that jus needs brakes
where are these people b4 i spend my hard eaRNED moneys lol
Old 07-13-2009, 10:43 PM   #8
JKs95stang
Quote:
Yes indeed, that sucks man, I hope you get her back on the road and save another stang.
You may want to have the heads checked out so you don't do all this work, and waste time and money and have to do it all over again.
JKs95stang is offline   Reply With Quote
Old 07-13-2009, 11:24 PM   #9
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
RyansQuick6's Avatar
Vehicle: 02 V6 with some stuff
Liek I told osmeone else earlier, try www.car-part.com and see if you can find a low mileage engine to slap in there. You can also go to www.SuperSixMotorsports.com and see about going with a 99-04 engine for a much more reliable setup.
__________________
Friggin OTards
Quote:
I learned an important lesson in the art of debate. Present your argument clearly, arm yourself with cutting wit and of course, bob and weave!
RyansQuick6 is offline   Reply With Quote
Old 07-14-2009, 12:07 AM   #10
JKs95stang
I would agree ryan, I'd rather swap a motor and trans, than do head gaskets, that's just me tho'.
96, 99, changing, coolant, cutlass, ford, gasket, gt, head, leak, leaking, losing, loss, mustang, oldsmobile, pony
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
