Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-24-2009, 04:43 PM   #1
fordforlife0225
Vehicle: 2004
Default car problem, video included. please help
so here it is.... i bought a used tuner on craigslist about 8 months ago and had justin tune it. ever since then the car has had a problem. the weird part is that its on and off. maby once a month for two days at a time that's it. im not blaming justin or vmp. they are awsome. it must be the used tuner. when i emailed the original owner he said "The only problem I ever had with it was when I used the custom tune it came with.so I just tuned it myself after that and never had any problem" whatever that means.
PROBLEM: ill go to start the car and it cranks but it turn over. in order for me to get it started i will have to crank it and then hit the gas. if i let off the gas the car stalls out. its like it is not getting any fuel unless i am hitting on the gas.
possible solutions:i checked just about every fuse and they all seem fine including the fuel pump fuse. i am about to go clean out the intake and throttle body with some throttle body cleaner to make sure nothing is sticking! other than that the only thing i can thing of is a new tuner. if i got a new tuner would this maby solve my problem. if i bought one from vmp and had them put a stock tune on it then maby it could erase the **** that is on there now??
__________________
****2004 ford mustang 40th anniversary edition, v6****
-sct3 tune -cold air intake
-cobra rear sway bar -tru dual exhaust
-kyb shocks and struts -rockford fostgate 12" sub
****2007 kawasaki ninja****
Quote:
Originally Posted by Hlistr_07RR View Post
so kindly take your heavy S197 and shove off
Quote:
Originally Posted by brian1570 View Post
i took it nice 'n deep like.
SEMPER PARATUS
fordforlife0225 is offline   Reply With Quote
Old 09-24-2009, 07:50 PM   #2
Fink
1999 Ford Mustang
Fink's Avatar
Vehicle: 1999 Ford Mustang
The only thing that I can think that would cause it would be the IAC.
__________________
Mods:
MAC LT's & O/R H, ROUSH Side Exhaust, GT Rear Sway, SCT X3, Auburn LSD w/ 3.27's
Waiting:
Cobra Brake Kit Front and Rear, KYB GR-2 Shocks/Struts (waiting on C/C plates)
now RS is gonna come in here and start sh!tting on his keyboard again.
Fink is offline   Reply With Quote
Old 09-24-2009, 09:52 PM   #3
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
RyansQuick6's Avatar
Vehicle: 02 V6 with some stuff
I sounds like a vaccum leak. But first, crank the car and unplug the IAC and it should die right away.
__________________
Friggin OTards
Quote:
I learned an important lesson in the art of debate. Present your argument clearly, arm yourself with cutting wit and of course, bob and weave!
RyansQuick6 is offline   Reply With Quote
Old 09-24-2009, 11:23 PM   #4
fordforlife0225
Vehicle: 2004
iac?? is that the hose going from the intake to the heads right before the intake hits the throttle body. besides the car dies right away as it is, or should i give it enough gas to keep it running then unplug it
__________________
SEMPER PARATUS
Old 09-25-2009, 01:37 AM   #5
stocksixer88
the iac is the little bypass valve attached to your throttle body... in the old days your throttle body butterfly valve had a hole in it to let enough air to pass through to keep the car running at idle.. now days you dont have that hole, it is done electronically via the iac valve..
its on the side of the throttle body.. it may be clogged or simply not working properly
stocksixer88 is offline   Reply With Quote
Old 09-25-2009, 12:52 PM   #6
fordforlife0225
Vehicle: 2004
think i found it
can i clean it or inspect it or can it only be replaced.
p.s my car started this morning. so weird
__________________
SEMPER PARATUS
Old 09-25-2009, 02:27 PM   #7
fordforlife0225
Vehicle: 2004
stopped by my local salvo auto parts store and talked to the guy about buying a new iac vavle he said they are 120 bucks which is not bad if it will fix my problem. he said that he had the same problem on his ford explorer and that ford makes ****ty iac vavles.
where can i buy this part online because alot of places around here dont carry the part
__________________
SEMPER PARATUS
Old 09-25-2009, 02:29 PM   #8
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
You can clean it and reinstall it
__________________
Friggin OTards
Old 09-25-2009, 02:43 PM   #9
fordforlife0225
Vehicle: 2004
out to the garage i go, thanks so much guys. im probably going to clean it and reinstall it and then order a new one from ford because i just got off the phone with them and they only want 75 bucks for a new one. and id rather not have to go through with this again id rather replace and know it is fixed.
__________________
SEMPER PARATUS
body, iac, mustang, sticky, throttle
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
