Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-28-2009, 02:33 AM   #1
xToPPxDoGGx
Vehicle: 03' V6 Ford mustang
Default pro charger and motor question
im starting research on the procharger for my car and i wanted to ask if there is any motor work that should be done, like stronger internals or any anything else?? im taking my time on this so if motor work is a good idea im willing to do it.
__________________
03' 3.8L V6 automatic
K&N cold air intake
ASP underdrive pulley
9mm Stang wires
Ford Racing Aluminum Driveshaft
True Duals with Flowmaster 40's
Diablo predator tuner on 93 Octane
Motive Gear 4:10's
Ford Racing T-Loc Slip Differental
xToPPxDoGGx is offline   Reply With Quote
Old 09-28-2009, 02:34 AM   #2
0949er
Vehicle: 2004 Mustang GT
how much power are you trying to make?
It depends.
__________________
MODS:
Comp Cam Stage 2's (XE 270AH)
BBK LT's
MAC O/R Prochamber
Borla Stingers
JLT Cold Air
4:10's
288 wrhp / 310 wrtq (Tune by Pro-Dyno.net)
"Supercharger Turbonator Stage 2"
NEW VIDEOS!!!
In Progress:
Vortech V-1 T-Trim 60% Parts, 0% Install
0949er is offline   Reply With Quote
Old 09-28-2009, 02:44 AM   #3
xToPPxDoGGx
about 280 or low 300, i just dont want to have to upgrade the rear end to an 8.8
__________________
K&N cold air intake
9mm Stang wires
Motive Gear 4:10's
Old 09-28-2009, 04:03 AM   #4
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
RyansQuick6's Avatar
Vehicle: 02 V6 with some stuff
You can hit 400hp easily without having to worry about internals, 450hp has been done, it's all in proper tuning.
__________________
Friggin OTards
Quote:
I learned an important lesson in the art of debate. Present your argument clearly, arm yourself with cutting wit and of course, bob and weave!
RyansQuick6 is offline   Reply With Quote
Old 09-28-2009, 11:24 AM   #5
0949er
Quote:
450 is pushing it. the agreed "safe" HP numbers for stock internals is 400 rwhp. anythign higher and its a gamble. yes it can be done. yes you might be able to get away without touching the internals, but its not for sure.
__________________
MODS:
BBK LT's
MAC O/R Prochamber
Borla Stingers
JLT Cold Air
4:10's
NEW VIDEOS!!!
In Progress:
Old 09-29-2009, 03:09 AM   #6
xToPPxDoGGx
well for the amount of horse power i want, just a guess about how much boost would i have to run, like i said just a rough guess
__________________
K&N cold air intake
9mm Stang wires
Motive Gear 4:10's
Old 09-29-2009, 01:18 PM   #7
BAMFingOh10
BAMFingOh10's Avatar
Vehicle: 2010 Ford Mustang V6
If you are running 350+ rwhp you will want to go for an 8.8... unless you want your gears to eat through the differential housing on your first launch at the track, or to have a bent axle.
BAMFingOh10 is offline   Reply With Quote
Old 09-29-2009, 04:05 PM   #8
ramoyer1
2001 Ford Mustang
My Garage
ramoyer1's Avatar
Vehicle: 2001 Ford Mustang
Send a message via MSN to ramoyer1
I got a 4.3 with a charger on it. but i upgraded my rear-end and blew out my transmissions 1st gear
__________________
NC Mustangs~~ http://mustangforums.com/forum/groups/nc-mustangs.html
1988 Mustang!~351w built,410's,700cfm carb,highraise intake,Lts,stright pipes
2001 Mustang!~built 4.2 from delkperformance,Diablo tuner,j-mod,ported lower,
windstar upper,cai,built 8.8 373s locker,h-pipe,mac cat-back,prochager,Longtubes,NOS 75 shot
1976 Camaro LT!~~Built LT1,400 heads,650cfm carb,410 posi,high raise intake,LTs,
1991 Honda Civic!~POS
1996 Mustang!~Nothing yet working on motor build...
ramoyer1 is offline   Reply With Quote
Old 09-29-2009, 04:47 PM   #9
mustangman02232
mustangman02232's Avatar
Vehicle: 04 F350 6.0
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
Quote:
your gears wont "eat" through your diff housing, and i highly doubt you will bend an axle, the first thing to go will be the spiders in the carrier, a detroit true trac w/girdle and a set of motive/ford gears and your 7.5 will handel 400 Ft lbs.
__________________
2004 Ford F350 6.0 PSD
MBRP 4" turbo back, no muffler/kitty, autometer boost/pyro/trans, SCT X-cal with innovative tunes, MISC appearance, fisher MM2,
not installed: arp head studs, cooling mods, 03 turbo, cfm "small mouth" elbow, ARP head studs, BPD EGR delete
SOLD:
2002 Mustang v6 vert
LTs, catted H, K&N FIPK, SCT X-3 with vmp tunes, misc appearance
RIP tripsevn7
4/1/77 - 7/27/08
mustangman02232 is offline   Reply With Quote
2004, horsepower, mustang, procharger, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
