Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-18-2009, 09:49 PM   #11
grabberorange1
2007 Ford Mustang
Had similar issue this week with my wifes exp., it would hardly idle but ran fine at higher rpms, it was a vacuum hose. I sprayed some starting fluid on the vacuum lines to help find the leak, replaced and runs like new. It must have been leaking for some time as it had a slight miss, thats all gone now...double check your vac lines.
__________________
grabberorange1 is offline   Reply With Quote
Old 10-18-2009, 10:34 PM   #12
neo8222
2000 Ford Mustang
Vehicle: 2000 Mustang V6
or not use a explosively flammable liquid might be safer...
__________________
Quote:
Originally Posted by fordforlife0225 View Post
dude you are the yoda of subs
Mods:
Sniper Tune
Heads, Cam, Stroke, Port n Polish, 3 Angle Valve job (courtesy of the last owner)
Spec Stage 3 Clutch and Aluminum Flywheel
MAC O/R H-Pipe and MAC Flow-Paths(do your self a favor and DON'T GET FLOWMASTER 40'S!)
3 Inch Drop
AM Cold Air Intake
NGK Iridium IX (TR6IX) Plugs, Performance Wires
1500+ Watt Stereo- JVC,Kicker,Infinity
neo8222 is offline   Reply With Quote
Old 10-18-2009, 11:01 PM   #13
rfcsoulja
rfcsoulja's Avatar
Vehicle: True Blue 01 v6
Quote:
Why the hell would you use starter fluid?
x2 on the checking your vac lines. The pcv tubes break down and need to be replaced. I just replaced mine and it fixed my vac lines.
__________________
2001 True Blue Mustang V6:
MAC CAI, True Dual Flow 40's w/ turn downs right before the bumper,MAC Long Tube Headers,Vap v3 windstar kit, 15% tint, eibach pro kit, Tokico shocks/struts, Detroit Tru trac, FRPP 3.73s, Custom Tune by Mike (Diablo Predator), mach 1 chin spoiler, grill delete.
Waiting to be installed: steeda short throw shifter.
rfcsoulja is offline   Reply With Quote
Old 10-19-2009, 12:07 AM   #14
neo8222
2000 Ford Mustang
oh i just thought why to use starter fluid... if theres a vacuum leak it sucks it in and changes the way the engine runs so you can find it.
__________________
Mods:
Sniper Tune
3 Inch Drop
AM Cold Air Intake
Old 10-19-2009, 02:28 AM   #15
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
RyansQuick6's Avatar
Vehicle: 02 V6 with some stuff
Yeah, you're supposed to use something somewhat flammable so that you can find the leak.
__________________
Friggin OTards
Quote:
I learned an important lesson in the art of debate. Present your argument clearly, arm yourself with cutting wit and of course, bob and weave!
RyansQuick6 is offline   Reply With Quote
Old 10-19-2009, 11:17 AM   #16
rfcsoulja
rfcsoulja's Avatar
Ahhhhh. . . . . .Makes sense.
__________________
Old 10-19-2009, 12:42 PM   #17
wolvrinewd
Vehicle: 2000, ford, mustang
My uncle recommended to use carb and choke cleaner to find the vacuum leak and start with one section of the engine at a time to find the area where there is a leak. Still unable to find one. Are there any specific vacuum lines I should look for that are known to leak? Should I check the metal lines too going from the EGR valve to the back of the engine bay?
wolvrinewd is offline   Reply With Quote
Old 10-19-2009, 11:00 PM   #18
Azrael
Azrael's Avatar
Vehicle: 01 SiXXXer Coupe
Send a message via AIM to Azrael Send a message via Yahoo to Azrael
You should probably check all of those lines (just as a precaution). However, your spontaneous misfiring is seemingly related to an electrical issue, most specifically, the coil pack. As far as the gas smell, I had that problem at one time, and an associated CEL. It turned out to be a rotted seal on the gas cap. Another thing to check is the charcoal canister under the car (right by the tank). Even the smallest leak in it will prevent the proper amount of gas from getting to the engine and will also cause a very notable gas smell. The only other thing I know of is the fuel pump failing, but I'm going to go ahead and doubt that.
__________________
Mods: FRPP T-Lok w/ 3.73 gears - Hurst T-Handle - MGW Short Throw - Cold Air Intake - Mach 1 wheels - Custom Straight Duals - WOT Mod - Custom Fuel Door - Rear Window Scoops - Panasonic Ghost Stereo w/ Alpine Type X Speakers - 3 MA Audio 10" Comp Subs
Coming Attractions: Cobra R 2000 Hood - Black FR500 Rims - HID's - High Lope Cam - Cut Springs - Stroked Motor
V - New pic needed...
Azrael is offline   Reply With Quote
Old 10-20-2009, 09:14 AM   #19
wolvrinewd
Last night as I was checking for vacuum leaks I noticed one of the plug wires was burnt half way through and not sitting on the plug all the way. It wouldn't go all the way on either. It must have gotten worse because it wasn't this way a week ago when I changed the plugs. So I changed out all the wires and it runs normal again. Thanks everyone for your input
Old 10-20-2009, 12:56 PM   #20
neo8222
2000 Ford Mustang
haha yup thatll do it, had that happen to me once. Clip the held the wires broke and they fell onto the exhaust.
__________________
Mods:
Sniper Tune
3 Inch Drop
AM Cold Air Intake
2000, bad, car, check, engine, gas, light, mustang, no, poorly, put, recently, runs, shakes, shows, stalls
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
