Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-30-2009, 10:43 PM   #1
Patrick16
Vehicle: 95,ford,mustang
Default My 95 Mustang wont fire???HELP PLEASE!
Ok,so i bought a 95 mustang 3.8 as a fixer upper hoping i could have it ready by the time i turned 16.It will turn over but wont fire?Well im 16 now and still cant figure out whats wrong with it.My uncle parked it about three years ago(it ran when he parked it) because he got a new truck,he thought the neutral safety switch was going out in it but it ended up being a bad connection to the starter.A guy that was looking at it accidentally put the battery in backwards and i think it fried the ecm so i installed a new one today.well it still wont fire.i also replaced the crankshaft position sensor.as well as the coil and the plugs.Does anyone know what the problem could be?
Thanks for your help
Patrick16 is offline   Reply With Quote
Old 09-30-2009, 10:56 PM   #2
JUSTA6
JUSTA6's Avatar
Vehicle: 2000 muastang
have you done you basic diagnostics yet.
fuel pressure and spark. pull a boot off the plug and crank it see it the plug wires are aLL firing. dont go wasting money by throwing parts at it hoping that something you thow on it will make it run
JUSTA6 is offline   Reply With Quote
Old 09-30-2009, 11:00 PM   #3
Patrick16
none of the plugs are firing,thats the problem.And i did the basic diagnostics.including the fuel pressure and it was good.
Old 09-30-2009, 11:09 PM   #4
JUSTA6
JUSTA6's Avatar
have you checked the coil pack
Old 09-30-2009, 11:10 PM   #5
JUSTA6
JUSTA6's Avatar
try testing resistance across the coil pack
Old 09-30-2009, 11:24 PM   #6
Patrick16
i did its getting voltage.if thats what your talkingabout
Old 10-01-2009, 02:47 AM   #7
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
RyansQuick6's Avatar
Vehicle: 02 V6 with some stuff
WIth a battery being installed bachwards, alot of things could have been messed up. Pull every fuse and relay one at a time and test them, that's the best place to start.
__________________
Friggin OTards
Quote:
I learned an important lesson in the art of debate. Present your argument clearly, arm yourself with cutting wit and of course, bob and weave!
RyansQuick6 is offline   Reply With Quote
Old 10-01-2009, 05:04 PM   #8
Patrick16
i did that also,theyre all good
Old 10-01-2009, 05:33 PM   #9
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
Is the fuel pump working?
__________________
Friggin OTards
Old 10-11-2009, 08:22 PM   #10
Patrick16
yeah it works fine
1997, 3.8, 95, bad, coil, fire, ford, fuel, mustang, mustang 95, pack, start, turn, wont, wont start
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
