Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-30-2009, 12:30 PM   #1
champ7
Default Help with p0114 code 2000 v-6
Hello my daughter 2000 Mustang is showing code p0114, can someone tell me where to start looking from easiest to fix to hardest to see if I can clear this code and fix, right now when she tries to excelerate car dosen't want to go, has to back off on throtle and feather it up to speed , not to good when entering a busy highway, also battery light comes on when this happens, kind of think this is just a side effect of what going on. replaced battery, was time to 10 yrs old long life, and pulled alternater and had checked just to make sure, was ok. Thank you in advance for any help. Steve
champ7 is offline   Reply With Quote
Old 10-30-2009, 06:34 PM   #2
mustangman02232
mustangman02232's Avatar
Vehicle: 04 F350 6.0
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
http://www.troublecodes.net/Ford/
__________________
2004 Ford F350 6.0 PSD
MBRP 4" turbo back, no muffler/kitty, autometer boost/pyro/trans, SCT X-cal with innovative tunes, MISC appearance, fisher MM2,
ordered: arp head studs, cooling mods, 03 turbo, cfm "small mouth" elbow, ARP head studs, BPD EGR delete
SOLD:
2002 Mustang v6 vert
LTs, catted H, K&N FIPK, SCT X-3 with vmp tunes, misc appearance
RIP tripsevn7
4/1/77 - 7/27/08
mustangman02232 is offline   Reply With Quote
Old 10-30-2009, 09:33 PM   #3
neo8222
2000 Ford Mustang
Vehicle: 2000 Mustang V6
P0114 Intake Air Temperature Circuit Intermittent... replace the temp sensor in the air intake tube.
__________________
Quote:
Originally Posted by fordforlife0225 View Post
dude you are the yoda of subs
Mods:
Sniper Tune
Heads, Cam, Stroke, Port n Polish, 3 Angle Valve job (courtesy of the last owner)
Spec Stage 3 Clutch and Aluminum Flywheel
MAC O/R H-Pipe and MAC Flow-Paths(do your self a favor and DON'T GET FLOWMASTER 40'S!)
3 Inch Drop
AM Cold Air Intake
NGK Iridium IX (TR6IX) Plugs, Performance Wires
1500+ Watt Stereo- JVC,Kicker,Infinity
neo8222 is offline   Reply With Quote
Old 10-30-2009, 11:10 PM   #4
champ7
where is this temp sensor located .is this the one that can be cleaned that is located inside the intake tube. Thank you
Old 10-30-2009, 11:46 PM   #5
neo8222
2000 Ford Mustang
no its the one poked into the rubber pipe on the intake and they are only $15 best off replacing it its the one with IAT pointing to it. just unplug it and pull it out literally then just literally push the new one in (at autozone its called a "air charge sensor" part number SU2004)
__________________
Mods:
Sniper Tune
3 Inch Drop
AM Cold Air Intake
Old 11-03-2009, 07:57 PM   #6
champ7
I found out That I was Given the wrong code the check motor light is coming on again and it is p0441, so where should I begin lookinh from easiest to fix to hardest. Thank again for the help in advance. Steve
Old 11-03-2009, 09:55 PM   #7
neo8222
2000 Ford Mustang
p0441 indicates that a part of the EVAP control system is not fuctioning correctly. Could be anything from the gas cap, fuel lines, carbon canister, purge valve, and other hoses. The EVAP prevents the escape of fuel vapors from a vehicle's fuel system.
the first place to check is replace the gas cap
__________________
Mods:
Sniper Tune
3 Inch Drop
AM Cold Air Intake
Old 11-03-2009, 10:33 PM   #8
champ7
Thanks for the help.
Old 11-04-2009, 06:19 PM   #9
champ7
Ok tryed another know working gas cap same code yet, so where to next, is they any way to pin point which part is bad or do you have to go to the ford dealer to have them pull code and find out which part is bad. Has this been a problem that others have had ,and is it a know part that mainly goes bad in the EVAP control system? On the V6 Mustang 2000. Thank you again
Old 11-04-2009, 06:42 PM   #10
neo8222
2000 Ford Mustang
did you clear the code after installing new gas cap?
the code doesn't specify what is bad just a general idea next one to check would probably be the carbon canister
__________________
Mods:
Sniper Tune
3 Inch Drop
AM Cold Air Intake
2000, air, code, mustang, p0114, replace, sensor, temp, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
