my setup happens to consist of a 12" alpine type R powered by a 1200W amplifier...Kenwood head unit. i ripped that annoying 6disc changer out of there.. idk why people love it... my amp is de-tuned massively bc it is more than enough bump for me. i lsiten to rap and this thing BUMPSSSSSSSSSSS...i can also adjust the subwoofer output with my adjustable bass controllre that came from rockford on the amp that stretches under my dash so i can just reach under and turn the knob down, OR i can juust turn the bass up or down using my head unit... it was $100 head unit i think and it looks great and performs even better
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
Things to do:
1) Fix exhaust leak
2) Remove isolators
3) Get rear decklid shaved and painted DONE
4) Get fog lights sprayed with black/clear mix
5) Get lower valence re-sprayed
yeah just rip the 6 disc so much easier and better sound quality plus you can sell it on ebay for almost the price of your head unit i sold my stock radio n cd player for $75 on ebay with a broken front cover
__________________
Quote:
Originally Posted by fordforlife0225
dude you are the yoda of subs
Mods:
Sniper Tune
Heads, Cam, Stroke, Port n Polish, 3 Angle Valve job (courtesy of the last owner)
Spec Stage 3 Clutch and Aluminum Flywheel
MAC O/R H-Pipe and MAC Flow-Paths(do your self a favor and DON'T GET FLOWMASTER 40'S!)
3 Inch Drop
AM Cold Air Intake
NGK Iridium IX (TR6IX) Plugs, Performance Wires
1500+ Watt Stereo- JVC,Kicker,Infinity
I love the clean stock look of the mustangs and dont want to stick a shiny silver headunit in it with all those different displays and ****. i like my clock and green volume bars lol. when my car gets back from getting a new subframe and lower control arm and two new airbags im gonna take it up to a custom speed and sound shop around here and ask them about installing a single 12 with a matching amp and bass controler.
__________________
****2004 ford mustang 40th anniversary edition, v6****
-sct3 tune -cold air intake
-cobra rear sway bar -tru dual exhaust
-kyb shocks and struts -rockford fostgate 12" sub
****2007 kawasaki ninja****
Quote:
Originally Posted by SKAR
Ive always made lavish clothing out of the baby seals ive clubbed.
Quote:
Originally Posted by 1987MustangGT5.0
If I had a vagina I'd be much more giving with it.
also i saw someones reply on tapping the speaker wires from the rear subs for the input.... DO NOT DO THAT a amp is meant to take under 5 volts of power the wires going to the factory subs are over that and will most likely damage your amp after a short period of time.
I said use an amp that specifically has speaker level input capability. So it is designed to handle using speaker inputs. 3 Years, no issue.
oh yeah the high level input thing... i never liked it, i installed one in my friends car and it worked but compared to a comparable low level input system it sounds awful. the high level inputs are really susceptible to interference and aren't able to be controlled as good with bass controllers or EQs
__________________
Mods:
Sniper Tune
3 Inch Drop
AM Cold Air Intake
yeah thats what i was talking about. just before you power up double check and even triple check all connections, or else you could get some of that mysterious blue smoke that usually makes things not work no more... or violently explode in flames
__________________
Mods:
Sniper Tune
3 Inch Drop
AM Cold Air Intake
Well, I'm going to add my $.02 here: I have a sub sys in my car as well. Right now, I've got 3 10" subs in a custom box. It fits the given space perfectly, and even leaves a bit of room for stuff (groceries, pool cues, guns, whatever the hell it is that you haul in a Mustang). I can fit about $100 worth of groceries in my trunk still, without a bit of room left. As far as wiring goes, I would buy the setup you want first, then take it to have the wiring done by a professional. As it stands though, I have never listened to my system at max volume, so 3 subs is probably the maximum. At 75% sub power and volume up to 30 out of 40, my system can be heard from ~1 mile away. The trunk rattles (badly) as does the speaker deck under the rear window. Still, with sub power at 50%, you can avoid rattle, and still have your ears bleed.
Just a glimpse:
__________________
Mods: FRPP T-Lok w/ 3.73 gears - Hurst T-Handle - MGW Short Throw - Cold Air Intake - Mach 1 wheels - Custom Straight Duals - WOT Mod - Custom Fuel Door - Rear Window Scoops - Panasonic Ghost Stereo w/ Alpine Type X Speakers - 3 MA Audio 10" Comp Subs
Coming Attractions: Cobra R 2000 Hood - Black FR500 Rims - HID's - High Lope Cam - Cut Springs - Stroked Motor
V - New pic needed...
Reason: Added Photo
