Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-01-2009, 09:51 AM   #11
Synyster06Gates
2000 Ford Mustang
Vehicle: 2000, Ford, Mustang
Yeah they say to use it in the tank when you have about 1/8-1/4th tank left.
__________________
170 rwhp/201 torque
2000 Mustang 3.8 V6
Divorced Duals - Thrush Welded Series Mufflers - 3'' tips
Hurst short throw shifter
FRPP T-Lok + 4.10s
Synyster06Gates is offline   Reply With Quote
Old 11-01-2009, 10:34 AM   #12
fordforlife0225
Vehicle: 2004
no pretty sure that is wrong. the label reads that X pts of seafoam treats X gallons of gas. i dont remember the numbers cuz i dont have a can at my house right now but 1/3 of the can works out to between 3/4-full tank of gas.
what does not mix immediatly with gas, will when u take it for a drive. when u add it to the oil and the vacuum line it is designed to work instantly to clean the fuel injectors.... hence the immediate smoke. when it is added to the tank it is designed to work with that whole tank for a week
__________________
****2004 ford mustang 40th anniversary edition, v6****
-sct3 tune -cold air intake
-cobra rear sway bar -tru dual exhaust
-kyb shocks and struts -rockford fostgate 12" sub
****2007 kawasaki ninja****
Quote:
Originally Posted by SKAR View Post
Ive always made lavish clothing out of the baby seals ive clubbed.
Quote:
Originally Posted by 1987MustangGT5.0 View Post
If I had a vagina I'd be much more giving with it.
SEMPER PARATUS
fordforlife0225 is online now   Reply With Quote
Old 11-02-2009, 01:13 PM   #13
03shadow
2003 Ford Mustang
My Garage
03shadow's Avatar
Vehicle: 2003, Ford, Mustang V6
ok that makes sense then. i figured it would work instantly with the oil and vacuum lines but didnt understand how it worked with the gas
__________________
2003 Dark Shadow Gray Metallic
V6 Pony Package
Visuals: tinted windows, GT fog lights, Mach I chin spoiler
Performance: Mac CAI, dual exhaust w/ flowmasters & hpipe
03shadow is offline   Reply With Quote
Old 11-02-2009, 06:29 PM   #14
neo8222
2000 Ford Mustang
Vehicle: 2000 Mustang V6
the idea is that it will help degum your lines and pump n all that.
__________________
Quote:
Originally Posted by fordforlife0225 View Post
dude you are the yoda of subs
Mods:
Sniper Tune
Heads, Cam, Stroke, Port n Polish, 3 Angle Valve job (courtesy of the last owner)
Spec Stage 3 Clutch and Aluminum Flywheel
MAC O/R H-Pipe and MAC Flow-Paths(do your self a favor and DON'T GET FLOWMASTER 40'S!)
3 Inch Drop
AM Cold Air Intake
NGK Iridium IX (TR6IX) Plugs, Performance Wires
1500+ Watt Stereo- JVC,Kicker,Infinity
neo8222 is offline   Reply With Quote
Old 11-02-2009, 08:40 PM   #15
Matt's 95 Stang
Matt's 95 Stang's Avatar
Vehicle: 1995, 3.8, Silver Coupe
I didnt chance the plugs afterword and havent had a problem.
Matthew
__________________
3.8L '95 Coupe -
Mach 1 brake kit and chin spoiler, GT foglights, CAI, '99 GT 17's, true duel, GT rear sway and strut tower brace bar, Steeda Tri Axe, Aluminum grill, 05' shift knob, limo tint.
Matt's 95 Stang is offline   Reply With Quote
Old 11-03-2009, 09:45 AM   #16
rfcsoulja
rfcsoulja's Avatar
Vehicle: True Blue 01 v6
I wouldn't use the brake booster line. I just took off my upper intake and the ONLY one that was clean was the ports to cylinder 6 which was coincidentally the one that has the break boaster right over it. I'd put it in the pcv port on the top of the intake.
__________________
2001 True Blue Mustang V6:
MAC CAI, True Dual Flow 40's w/ turn downs right before the bumper,MAC Long Tube Headers,Vap v3 windstar kit, 15% tint, eibach pro kit, Tokico shocks/struts, Detroit Tru trac, FRPP 3.73s, Custom Tune by Mike (Diablo Predator), mach 1 chin spoiler, grill delete.
Waiting to be installed: steeda short throw shifter.
rfcsoulja is offline   Reply With Quote
Old 11-03-2009, 09:51 PM   #17
ThunderMoon1994
Vehicle: 1999 Ford Mustang
I know this is probably a stupid question, but can someone please post a pic of the vacuum line and how to properly put the Seafoam in? I would really appreciate it.
ThunderMoon1994 is offline   Reply With Quote
Old 11-03-2009, 10:55 PM   #18
fordforlife0225
Vehicle: 2004
id do a video on it but my car is up on a lift at the body shop i work at and it just got its new subframe and lower control arm in so she aint feeling to well.
p.s.
it is NOT the brake booster linebtw. it is the vacuum line and it is the same line every dealership, jiffy lube, and other shop uses to induce injector cleaner
__________________
SEMPER PARATUS
Old 11-03-2009, 11:30 PM   #19
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
RyansQuick6's Avatar
Vehicle: 02 V6 with some stuff
I actually called seafoam about this, you can run 1/3 of a can in the oil for 5k miles and it won't hurt anything. Just gives it more time to work it's "magic"
__________________
Friggin OTards
Quote:
I learned an important lesson in the art of debate. Present your argument clearly, arm yourself with cutting wit and of course, bob and weave!
RyansQuick6 is offline   Reply With Quote
Old 11-03-2009, 11:56 PM   #20
rfcsoulja
rfcsoulja's Avatar
p.s.
They also use a pressurized system that intorduces the cleaner in a mist form which would allow it to flow more evenly throughout the intake. Your everyday Joe isn't using a pressurized machine. I'm letting you know what I saw. All my ports were dirty as hell except for the ports to cylinder 6. It might be a coincident, I dunno. I can't really see how that was the ONLY one clean though. So it's 1 of 2 things. 1. Seafoam doesn't work for crap as my intake was caked with carbon deposits (except #6), or 2. seafoam only cleaned out the ports that in which it was introduced directly above.
I apologize for calling it the "brake booster" line instead of "the vacuum line that leads to/from the brake booster". At a few of the shops I've worked at, we only used "the vacuum line that leads to/from the brake booster" when we couldn't put it in front of the throttle body in the intake tube.
__________________
2000, 99, body, cut, cyl, engine, ford, fox, gt, line, mustang, s197, seafoam, stuff, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
