Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-01-2009, 09:45 PM   #1
lil 98
1998 Ford Mustang
Vehicle: 1998 Mustanggg
Default fuel problem..need help asap
so the other day i decided i wuz gunna paint my upper intake manifold black to give me sumthing to do..so i undid the cold air intake, disconnected everything, and took it off. i had done it before so i knew where all the hoses and connections went..plus its not hard to mix up(iv gotta 98 v6 btw, 3.8) and i painted it and i took the throttle body off and cleaned it up with sum throttle body cleaner and i did the upper intake too. and i put it on..i had a little trouble with the gasket from manifold to manifold but i got it in there. but i put everything on, hooked it up, started it and it was idling wayyy to high and it wanted to stick when it came down from a rev up..iv been looking for sum answers and the check engine light eventually came on and i read it with a scan tool and it came up that both bank 1 and 2 were running lean. i had messed with the set screw on the throttle body before but it ran fine up till now. so i adjusted it and checked codes and i keep getting the same thing..it seems to b idling fine as best as from wut i can tell, its not dramatically all up and down at idle but its sumwut normal. however the codes are still coming up after clearing them over and over again. im stuck on whats wrong. idk if maybe its a hose i MAY had mixed up or a solenoid going bad or sumthing else..i need help fast because im worried about the engine possibly overheating bcuz of the lack of fuel..
lil 98 is offline   Reply With Quote
Old 11-01-2009, 10:18 PM   #2
brent4
brent4's Avatar
Vehicle: 02 Sixxer
Idk if this is where your problem stems fron but when ive had an issue with bank 1 or 2 being to lean its because of an o2 sensor. What exactly are the codes its throwing?
brent4 is offline   Reply With Quote
Old 11-01-2009, 10:43 PM   #3
lil 98
1998 Ford Mustang
its throwing p0171 and p0174
Old 11-01-2009, 11:01 PM   #4
SKAR
Luzerator
1983 Ford Mustang
My Garage
SKAR's Avatar
Vehicle: 1983 & 1990
Id suggest checking the gasket for the throttle body.
__________________
SKAR is offline   Reply With Quote
Old 11-01-2009, 11:11 PM   #5
lil 98
1998 Ford Mustang
iv actually been looking around and figured id go ahead and skip work tomorro and get the gaskets for the top end (tb, upper intake, n egr) and give that a go..idk how to check my fuel pressure but i might ask one of my friends who's a mechanic and ill c where that goes..im gunna go ahead and tear it all down and check for vacuum leaks and try the new gaskets i spose. hopefully it may clear up the problem but idk
Old 11-02-2009, 05:43 PM   #6
lil 98
1998 Ford Mustang
so turns out i needed a new egr gasket and new upper intake gasket to fix it. i took a trip over to napa and got them both for about 15 bucks. i came home and took everything off popped the new gaskets in and put it all back together and she's running fine. turns out all i needed wuz a few new gaskets!
ford, fuel, mustang, problem
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
